Question about Dell Dimension 3000 PC Desktop
I reisntalled my windows and now there is no internet.
I thought i installed the drivers properly but the pc is not picking up the modem. i called my internet service and they said the NIC adapter is missing and then i called dell for it and they said they wont help me unless i pay the $49 techsupport fee. can somebody please tell me what to do?
    Genius:
  • 1,142 Answers
Go to
http://support.dell.com/
click on drivers and downloads then click on service tag or you can select a model and you can download all the drivers for free.
dont forget to rate the solution
Regards
Posted on May 09, 2009
  • 11,896 Answers
If you have the NIC card (ethernet card or dial-up card installed)
Go to control panel and go to device manager.
You will see NIC card on the menu
Go to the properties menu and click on update driver.
You can also also remove the card and reinstall, go to add/remove hardware and try reinstalling and download drivers.
Lastly you can search the internet for the drivers alone and download the latest ones.
I have an ETS2288 huawei modem with internet and I was provided with a CD driver for windows 98 or XP. My laptop is windows 7 and this CD driver does not work for it. Pls help me, what should I do to...
Mostly Huawei modem has a build in auto-installer.,might your usb,ethernet driver ect. on your pc is not properly installed on your pc. Try to update your drivers provided the CD on your laptop to be to recognized all of the devices you plug-in to your computer.
good luck...
Jun 24, 2011 | Computers & Internet
Emachines EL1850 internet connection problem, brand new out of the box computer will not connect to the internet. Its not the modem or an internet problem, as i'm using the internet and modem to write...
hi,
other computers are working fine in your modem?in that case you need to check if your pc can detect the modem,or you can check if the ethernet driver (for LAN connection) and/or wireless driver (for wifi) are installed correctly...you can check that in the device manager if the drivers are properly installed
if Windows 7 - click start ; on the start search area, type device and the look for device manager
look for network adapters and you will see there you lan and/or wireless adapter
Thanx
Jan 05, 2011 | E-Machines eMachines Desktop PC
Unable to connect to internet. Only two lights show -- power & dsl. When I called for help I was told I needed a new ethernet cable. Bought that & installed. Same problem -- only two light lit...
In all there should be lan led, dsl led, power led and internet led,
So if dsl and power led is glowing and others not?? than check the lan cable and even check the lan card of ur pc is it enabled or drivers are properly installed and same way try to check the modem configuration??
Sep 08, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Formatted my laptop ,installed windows xp pro now my modem has problems dialing .
If you have modem driver install driver properly If dont have then search from Internet and Install them
Aug 30, 2010 | Sony VAIO Notebook
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
Resuming verizon dsl usb internet connection
If you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
May 18, 2009 | Westell Wirespeed ProLine 6100 Router...
Internet Connection - Operating System drivers for WinXP (Packard Bell EasyNote E2310)
you have to install the original windows in able to perform the computer well and to work the driver properly, sometimes if you install the pirated xp windows the driver wont work properly specially the wireless network.
you can find the driver thru the internet dell website.
Apr 15, 2008 | Computers & Internet
Installing wireless modem
To download the most appropriate modem driver for your Windows XP computer, a few steps is indispensible to finish the whole process.
Step 1
Look at the modem. Write down the make and model. If you have a dial-up modem in your computer, take the panel on the tower off. Shine the flashlight on the device. On the circuit board, the manufacturer and/or model number is present.
Step 2
Locate an Internet connection. To download Windows XP modem drivers, go to the library or someone's home where the Internet is able to connect. If you have another working modem in your house, you can download them directly to your computer.
Step 3
Go to the manufacturer's official website or a Windows XP modem driver's web page. Windows XP Drivers, Drivers Kit and Driver Support Registry have modem drivers for the Windows XP operating system.
Step 4
Click on the modem device. Select the manufacturer of the modem. Some of the driver sites are XP only, while others are all drivers. You will have the chance to choose your operating system before downloading. Click on the "Download" tab. Wait approximately 10 minutes, depending on the speed of the PC and Internet connection.
Step 5
Burn it to a disk. If you are at another location, you need to burn to CD/DVD for transportation.
Dec 22, 2007 | Belkin (A3X1627-06KIT-M) Modem
Wizard software installation
You can disable this piece of software within the windows registry or from the "Start", "All Programs", "Start Up" folder.
At least you can turn it off until you find the correct disk to un-install it.
In some cases, if you have the correct disk, reinstalling the software is necessary prior to un-installing.
Dec 12, 2007 | Sony VAIO FRV28 Notebook
Dell Dimension 3000 PC Desktop Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
