Question about Jandy LAARS LX400 - NATURAL GAS, DIGITAL READ-OUT, LOW NOX
I get a message saying Hi Lim SW when trying to heat my spa. What does this mean?
  • jaime8more May 11, 2010
    jandy lx 4oon-lcp
  • 116 Answers
Hi limit switch heating unit getting too hot what type of heater are you using
Posted on May 11, 2009
LAARS LX250N-L error code AIR FLO SW and sometimes a HI LIM SW cannot locate the source of the problem?
hi limits are located under where the pipes go into the heater if corroded replace if wires bad replace to test you can jump them at the board only testing if left jumped heater could catch fire
Jun 29, 2015 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
What does sw open mean on the digital display mean
sw open means open switch check pressure switch to see if voltage both sides if ok check hi limits
Feb 03, 2015 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How do i correct a "high limit switch circuit is open" code
check the fusable link for voltage on both sides if not replace also check pressure switch
May 26, 2014 | Jandy LX 400P Lo-NOx, 400,000 BTU Heater...
Message says hi lim sw
replace hi limits ther are 2 of them
Jul 07, 2011 | Jandy Lx Pool & Spa Heater - Electronic...
My balboa spa says sl and isn't heating up
SLP or SL Message
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
COMMON SPA PANEL MESSAGES
May 19, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
My Jandy Pol heater is giving me an error message of Hi Lim SW which I believe means that it has something to do with the High Voltage somethihg or other. Can you please help me?
Thank you for posting your question here on Fixya.com.
Hi limit switched are embedded in the header and trip when the water temperature is too high. Most of the time the cause is either a faulty sensor or poor flow thru the heater causing the exchanger to overheat. If you have a bypass plumbed into the water lines at the heater close it and see if the problem goes away. If not, you'll need to check the limit switches to see if they are faulty or if a condition exists causing them to trip.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Fan for the heater will not come on showing service HI LIM SW on screen
That would mean the high limit switch. Check it and see if you can reset it. It may have gone bad. Check first and if needed find a replacement part. Good luck...Lee
Nov 25, 2009 | Jandy Lx Pool & Spa Heater - Electronic...
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Temp control failure (thermostat) high limit is safety to prevent over heat.
Jul 26, 2009 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
Hi Limit Switch error
this may be for two reasons first the water is going to slow make sure filter is clean and either the water inlet plump incorect or the valve assembly is damage and need to be replace the high limit is letting you know the temp is getting to hot inside the heat exchanger
Jun 06, 2009 | Jandy Laars Lt 250,000 Btu Heater
Jandy LAARS LX400 - NATURAL GAS, DIGITAL READ-OUT, LOW NOX Logo
469 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
