Question about Sony KP-44PX3 44" Rear Projection Television
Lost remote..can get PIP feature back to one image
The picture shows two screens side by side. Can't get it back to one screen without the remote..
  • 92 Answers
Try to get into the menu and reset to manufacture defaults, if not a universal remte made by sony will work
Posted on May 10, 2009
How do i get the pip, Picture in picture to work ??
If it has the feature buttons on the remote for it, swap, position etc.
Some older sets have to have signal routed to one of the rear video inputs for a source for the PIP. Newer sets have two tuners--one for main and one for PIP---if pulled up the swap will switch one picture for the other--some allow both on the screen at same time side by side.
Read the owner manual to see if the set has PIP.
Jun 12, 2012 | RCA P52960 52" Rear Projection Television
I HAVE A BLACK SUZRE BOX SHOWING AT THE BOTTOM OF MY SCREEN. SOMEONE TOLD ME THAT IT WAS THE PICTURE IN PICTURE. HOW CAN I GET THIS BLACK SQUARE OFF OF MY SCREEN.
That's a text box not pip. Press the cc button repeatedly on your remote control or go into your menu and find the closed captioning setting. There may not be a menu item for closed captioning. It might be a button on the remote only. You should be able to scroll through the closed captioning options when pressing the cc button to choose off. You are more likely in the text1 or text2 mode right now. If I am wrong and it is pip there should be a pip button that will enable you to turn this feature off (or a menu option). If you need the remote that originally came with this television try http://www.replacementremotes.com/
Jul 22, 2011 | Televison & Video
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
How do you split the screen to watch two different shows at once?
to watch two defferent channel in one screen,u just need to activate the PIP feature of you tv..PIP means picture in picture.
May 20, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I lost remote is there away to manually change tv black panels back to full screen like the aspect button without a remote? the tv is a hitachi 51f500
Unfortunately, most of these projection TV's require a remote. You CAN purchase an aftermarket remote. I would look for one that has all the features you need, PIP, screen format etc.... I have found that the Sony RM-VL600 works real well with my Mitsubishi TV... kids thrashed the remotes more than once...
This particular unit has system control PROGRAMABLE buttons on the bottom row. I've been able to program them for formatting the screen, setting audio and video... Solved my issue of needing a factory remote... KEN
Mar 31, 2009 | Hitachi 51F500 51" Rear Projection...
Image too big for screen
I have the same tv.
On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
Dec 03, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Problem with Onn TV
I called the ASDA helpline and a lovely lady called Kirsty told me to hold down the pip/pop button. It worked fine.
(allways go to the source)
Jul 24, 2008 | Televison & Video
Changing channels on pip feature
I THINK YOU HAVE TO TRY TO SOLVE THE PROBLEM WITH THE REMOTE CONTROLLER SHOULD BE  FIND A KEY FOR
USE PIP
Dec 06, 2007 | Televison & Video
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
Sony KP-44PX3 44" Rear Projection Television Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
