Question about Samsung Televison & Video
Lost video on a Samsung 42" HPR 4252 Plasma all other functions are go...there are 2 buffer boards that appear to be video drivers on the left side (inside from back) What is the likely hood of these boards being the correct ones to replace?
  • jpdemarco May 09, 2009
    Noted....already been to this sight (shopjimmy) and searched for the "presumed" correct board. One additional point.....when noticing the lost video there was soon an "burning electronics smell" emitting from the TV. When shutting down and removing the rear panel it "seems" the burnt smell was originating from these two boards ..."upper and lower buffer boards"...as they are called on shopjimmy. In addition, they have 6 ribbon cables that run to the front of the screen. So, my thought is ..that these were the correct boards. Secondly, when looking for parts on this model.....these are the most popular parts purchased on this model.... coincidence or not relative?
    ShopJimmy's server seems to be down at the moment...
    Thanks for your help.....
    President:
  • 1,197 Answers
HI jpdemarco.....
its right.... it is the upper and lower buffer boards thats causing ur problem..... u will have to replace both.... if it was just the lower buffer board only the bottom half of ur tv wud go blank....... since both the upper and lower boards of a tv has gone bad..... ur entire screen is bad......
just to assert my fact... i came across this link on the net...... the user had a problem of blanking in the bottom of the screen
http://www.justanswer.com/questions/1rc09-hello-samsung-hp-r4252-42-plasma
u need to replace both the boards thank you have a nice day and good luck with ur tv...
Posted on May 10, 2009
    President:
  • Samsung Master
  • 2,923 Answers
They are called the inverter boards. You need to replace the interter board of your Plasma so that the video would come back.
Here, I provided you the link where you can see the inverter boards:
http://www.shopjimmy.com/catalogsearch/result/index/?q=INVERTER+BOARDS&stock=all
Have a great day!
Posted on May 09, 2009
I have a Samsung Plasma 4252 and i have red horizontal lines running across the top section and lower sections of the screen. here is a couple images: http://img.photobucket.com/albums/v490/rd1tib/1-1.jpg...
I have the same problem on my set. I had a repair technician out today and they wanted to replace the circuit board that the buffers are connected to and the adjacent board that drives the buffers. If you remove the back panel the buffers that are in line with the distorted areas on the screen are running super hot. Estimated price with labor was $700.
Jul 13, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung Plasma 42" TV Screen problem
panel migth be bad, connection/connector on it might have loosen up already! it it has a warranty then return it at once and ask for a new one! its what you've paid for.
Nov 18, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Turn on my tv samsung HPR 4252 and I get no sound or picture
DOES THE TV TURN ON , HAVE YOU TRIED OTHER SOURCES LIKE DVD ,DID YOU CHECK YOUR HDMI CABLE IF ALL OF THIS SEEMS GOOD IT LOOKS LIKE A DEFECTIVE MAIN BOARD REPAIRE ABOUT 325 DOLLARS
May 31, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
We have lost a two inch wide black section on the right side of the plasma panel, any ideas
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Oct 25, 2009 | Samsung PS42P2S 42 in. Plasma Television
Samsung HP-R5052 50 bottom hallf screen turns black
its the lower buffer card.. (y buffer lower board) they cost about $90.. i changed mine myself on my samsung hpr-4262 42 inch plasma.. pretty easy,, took approz 20 minutes.. the card has 3 ribbon cables and 3 other connectors and 1 screw.. removing all the screws out of the back pannel took the most time.. i found the repair manual for my tv on line for $13 (download PDF file) the manual had a trouble shooting section and what board to replace for each problem.. got the manual from here http://store.payloadz.com/ ordered the replacement board from www.partstore.com
good luck
troy
Jun 24, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Black Line on Samsung TV Model # HPR-4252
This is a screen address failure from part of the matrix addressing. This can be caused by fair number of types of faults to cause a missing part of the addressing. You will not be able to fix this yourself.
Find out who the authorised local Samsung service is for your area. They will be able to give you an estimate.
Jerry G.
Jun 03, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Televison & Video Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
