Question about Toshiba Satellite A100-S8111TD Notebook
Cannot connect psp to wireless router. pc works fine
Computer works fine with wireless router but cannot get psp or wii to go on internet put in right user name and passwords . have i got to change some settings on my pc
Cant connect to my router netgear
http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    Nov 26, 2011 | NetGear WGR614 Wireless Router
    Activate internet
    Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the psp" button. Now, select "psp Settings" to access the "System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point." Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours Select "OK," "Save Settings," and then "Yes."The psp console will run a connection test with your wireless network when the test is completed. You should see the following screen.Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the psp will begin to download any available updates.
    Dec 24, 2010 | Sony PlayStation Portable (PSP) Console
    Internet
    You have to configure your wireless connection within the PSP itself.
    Here's a guide for doing just that: http://www.pocketgamer.co.uk/feature.asp?c=307
    And make sure that your Wifi switch is in the right position (it'll shine a light when it's trying to search for a connection).
    Jun 05, 2010 | Sony PlayStation Portable (PSP) Console
    Cant connect wii to internet
    The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
    For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
    nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
    i hope this helps
    Nov 05, 2009 | Nintendo Wii Console
    TEW432-BRP Trendnet wireless broadband router wont connect
    Sounds like you need to configure the PC's USB wireless adaptor. The settings must be the same as the router. If you use a WEP password on the other connections then you need to have the same password on the USB wireless adaptor. Good Luck.
    Jun 30, 2009 | Trendware TEW-432BRP Wireless Router...
    Router not seeing internet connection
    If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
    Jun 09, 2009 | Linksys Wireless-G WRT54G Router
    Cant get may psp and my wii consoles to work
    This is the password to your wireless network.
    May 15, 2008 | Belkin (F5D7230-4) Router (587009)
    PSP internet problem ongoing
    has it ever connected to the wireless router if not try changing the settings of sercurty wpa-psk
    Sep 21, 2007 | Sony PlayStation Portable (PSP) Console
    PSP Internet Problem Cont'd
    Dont forget to check your WLAN switch on the left hand side, it must be slid to the up position.
    Sep 16, 2007 | Sony PlayStation Portable (PSP) Console
    Toshiba Satellite A100-S8111TD Notebook Logo
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
