Question about Garden
Mower not running at set speed, choking
Honda Lawnmower Starts well Runs well when fully choked When the mower is set to high or low speed the RPM runs high, low, high, low. The "governer" seems to be opening and closing the butterfly valve Cleaned and gapped the plug Changed the oil. Cleaned out old gas, even in float bowl and filled with fresh gas Lubricated all moving components on outside of mower Any ideas Mike
  • mlawrie May 10, 2009
    Thanks fancyface818
    I did double check your idea.
    This only killed the engine faster.
    The govener located in the oil pan assembly is connected to a lever that moves an arm, that is connected to the carbs butterfly valve.
    If I stop the arm from moving, this steadies the RPM, however with this device "disabled" the engine speed is not govened allowing the RPMs to increase to what I think could be near redline.
    I've included an image of the side assembly
    Item #1 in the govener arm. This connects to the butterfly valve using item #2
    The govener is item 7 and connects to the arm (outside) by item #12, below
  • Anonymous Mar 29, 2014
    Honda HRX475 SXE drives too slowly even when on high speed. I have adjusted clutch cable at handle end.
  • 82 Answers
You should have an air/fuel mixture screw on the carb somewhere. Start the engine and turn it one way then the other a small amount at a time. One way it will get worse and one way it will get better. Keep turning till it smooths out
Posted on May 09, 2009
  • fancyface818 May 10, 2009
    trust me the carb is either out of adjustment or it is dirty
Hi I have an mtd yardman ym 6021 sms Self starter, self propelled lawnmower. It starts reluctantly and then runs ok except it runs on full throttle all the time and you have to walk really fast behind it...
your primer is the choke the primer bulb pushes air in ti the bowl then it forces gas to inter the engine to make it start try spraying above the carburetor some wd 40 sounds like your throttle is stuck not letting your governor work ,happens alot
Apr 30, 2014 | Garden
Honda mower starts with choke but dies when turning the throttle down below the choke setting
This most likely just needs a tune up. Worst case would be a carb rebuild or just a simple adjustment to the low and high end of the carb. there are two screws on the side for adjusting this.
Jun 20, 2013 | Garden
LAWN MOWER ONLY RUNS ON CHOKE
RUN ONLY WITH CHOKE, IS FUEL PROBLEM. CHECK FUEL CAP TO REMOVE FUEL LINE FROM CARB. NEED FUEL RUN OUT LINE.
May 14, 2012 | Garden
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a jcb 5.5hp lawnmower, its starts with the choke closed, but as i open it, a begins to stop, it never use to do this, it always ran, when i opened the choke up, fuel is good
the choke should not be engaged when you are running your mower, it is only for starting cold engines and will choke you mower out if you open it up during operation. Only the throttle should be used to increase rpms
May 05, 2010 | Garden
Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Nov 23, 2008 | Garden
Garden Logo
1,112 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
