Question about Mitsubishi WS-55813 55" Rear Projection HDTV
Green LIght Blinking
The Green Timer Light won't stop.  It has been blinking for four days.  In the past it has come on and turned off within a few minutes and then you can turn on the TV but now it has been blinking for four days and it did go off once and I pushed the Power button to turn it on and the Green Blinking Timer light came back on, HELP ?
  • 4 more comments
  • Anonymous Nov 23, 2007
    green light blinks constantly andwon't turn off and no picture.
  • golfinputz Nov 25, 2007
    I have the same blinking light problem. Although I did already try on suggested fix, which was replace the four capacitors:C9B01, C9B02, C9B10, and C9B11. I replaced what I thought was a repaired DM module. I still have the blinking light. What would be the next problem to look for?
    Is this Dm module for the supply of power? Could there be a blown fuse internally, that would display the same symptom.
    Greg
  • Michael Kurtz Nov 25, 2007
    I pushed the reset button as indicated in the manual and still continues to blink. This has bee going on for 28 hours now.
  • Anonymous Mar 12, 2014
    Blinking green light when I push power button
  • Anonymous Mar 18, 2014
    Once I turn the television on to watch television, It turns right back off in a second. This happens repedately.
  • Anonymous Mar 31, 2014
    thr timer light in front of the tv screen
I'm no expert, but I did disconnect the tv from the power outlet and I waited about a minute. Then replugged back in and turned set on. Worked fine. I have a new problem tho--the tv turns itself off and the green light blinks fast for about a minute or so--then goes back to normal. Set works after light returns to normal but will do the same thing after a few hours of operation--Does anyone have any idea what's up with this? It appears to be something with the set I beleive---thanks SJK
Posted on Apr 04, 2008
    Problem Solver:
  • 9 Answers
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,its helpful if u have the warranty or protection agreement
Posted on Mar 26, 2008
Wd 62525 same blinking 5 day . reset and nothing.
Posted on Dec 11, 2007
Replace the DM or have someone repair the DM. The capacitors are bad and someone who knows how to repair circuit boards can replace them
Posted on Nov 06, 2007
2 Suggested Answers
SOURCE:
  • 1030 Answers
SOURCE: Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
[email protected]
Posted on Jan 08, 2008
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
[email protected]
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Dec 01, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Power Failure, now the power/timer blinking light won't stop blinking
Four bad caps in DM module = common repair for qualified
Mits tech.................................T.
Nov 03, 2007 | Televison & Video
Timer Light Blinking
Replace four caps in DM module 1000mf/25v 105 degree...
common repair for qualified Mits tech............T.
Oct 13, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Sep 13, 2007 | Mitsubishi WD-62525 62" Rear Projection...
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
[email protected]
Oct 24, 2006 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
287 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
