Question about Dell Inspiron 6000 Notebook
The screen is black and I can work only with an external monitor. Could you help me please. My laptopo is an Inspiron 6000. Thanks.
  • Dell Master
  • 1,800 Answers
Yea sure.
this happend when the flex cable that connects the main to sub its the lcd in this case to its time for new flex cable also its an esay part to replace and find especialy for you laptop.
Posted on May 09, 2009
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
My Inspiron 6000 screen is blank. I can get an image on a monitor through the serial port, but when on its own, the notebook screen is black. I have noticed that there is a brief flash when booting up, but...
Hi ,
1. You can check the display on external monitor>If the display is blank on external monitor also, its pretty clear that there is an issue with system board
2. If the Exernal monitor comes up fine, it will be an issue with the display of the laptop, you can cross check the issue by booting the computer to BIOS, IF you get same response on BIOS as well. Its an issue with the Display itself you can replace the display panel.
Hopefully, its covered under warranty ;)
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Toshiba laptop satelite a135-s2386. I went to turn on computer and there is power but the screen is black. Thanks!
connect an external monitor on the unit and press the key combination to get the video on an  external monitor this is different on some laptops on HP dv 6000 for example it is FN F4 if external monitor work the problem is with your laptop display if the external monitor doesn't work its probebly your systemboard als check your memory.
May 04, 2009 | Computers & Internet
Laptop inspirion 6000 screen went black, can only see shadows of windows but, it works. Please help. Thanks London
London the only option is to replace the display or the back light itself. If money is tight you then can use an external display but that does limit your mobility. I had a D610 go out on me but it would work if hooked up to an external monitor. Once I replaced the display it was fine.
Mar 18, 2009 | Dell Inspiron 6000 Notebook
Acer aspire 5220 booting problem
Try connecting to an external monitor. If it displays on the external monitor then the LCD is probably dead. If it doesn't display on the external monitor, its a problem with the video card.
Feb 25, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6400 screen black
you will need to have the Inverter on the screen replaced by a qualified technician
Feb 02, 2009 | Dell Inspiron 6000 Notebook
Inspiron 1150 screen is black
It is one of three things usually Bad cable at the hinge, Failed inverter board, or failed backlight. Probably inverter. Not to difficult to repair. Check cable first because it is inexpensive and easy. Check the inverter and replace if needed . Sometimes you can buy one used cheap with a bad motherboard and swap the top.
Jan 19, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
MY LAPTOP GIVE ME A BLACK SCREEN
hi!
black screen at startup? do you still see the Dell logo at startup? try pressing Fn+F8 at the same time at the black screen and see if it works. Or else, try a working external monitor and check if its a OS problem or a screen problem. You can also run a diagnostic test by holding down the Fn key while its off and then press the power button while still pressing on the function key to check if you will still see the diagnostic test for the LCD.
Dec 09, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 6000 Notebook Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
