Question about HP Color LaserJet 2600n Printer
Just replaced color inks but giving error 10.0002 Supply error
  • 400 Answers
Seems to be a problem with the magenta cartridge try removing it and reinstalling it also make sure you removed all the tapes that it had.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00314875#A8
This is what HP say :
Description E-label cannot be read or print cartridge is not properly installed. Action
  1. Open the front cover of printer and remove the toner cartridge exhibiting error.
  2. Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
  3. Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
  4. Inspect the e-label reader to ensure the gold contact points are not damaged or bent. Also inspect the black plastic on e-label reader to ensure it is not bent or broken.
  5. Reinstall the print cartridge.
  6. Power cycle the device.
  7. If reinstalling the print cartridge does not resolve the issue, replace the print cartridge.
  8. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Posted on May 19, 2009
Hp plotter T1200 ps gives error 22.1:10
Problem with "Ink Supply Station" P/NoQ6683-60188. Replace it..
If you are tech guy follow the suggestion:
Error reason: ISS divided in to two units, each unit will maintain that pressure to pump ink to print heads. The part called "rocker" push the elestomer bongo(black rubberized material) to pump ink. This rocker movement sensed by the respective sensors to calculate timely movement. If these sensors malfunction or variations in rocker movement causes error..
Remove/take out Ink supply station, two units of right & left, right unit not working properly, clean sensors & lubricate the drive shaft.. Follow the pics..,
Note: Technically if you are not sound don't do this activity..
2_16_2013_7_45_21_pm.jpg2_16_2013_7_45_46_pm.jpg2_16_2013_7_46_05_pm.jpg2_16_2013_7_46_30_pm.jpg2_16_2013_7_46_54_pm.jpg
Feb 16, 2013 | HP Designjet T1200 Large Format Color...
Only want to have the black ink installed in my Canon Mp480
You Can Press the Cancel and The Power Button At the Same Time...
And wait for around 5sec. It will Turn Off. And Again On It.
It will work without the Color Ink!!!
Sep 10, 2012 | Canon Pixma MP480 All-In-One InkJet...
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Gives me an error88/69
This error means you are out of ink. The error will show a colored box, that's the ink you are out of. The 88/69 is the type of ink you can replace it with.
Jun 16, 2009 | Epson Stylus NX400 InkJet Printer
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Error Message V163
well col probably stands for color.....i would try unplugging your printer for 10 seconds then plugging it back in....that resets the printers memory. did you buy the right black ink cartridge? that might throw a error code.
Sep 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
No Color Suppy Error Code
Try cleaning the print connectors on the cartridge housing area with a q-tip. This should resolve your problem, or else try to run ink cartridge test on your copier. Let me know if this fix your problem.
Mar 23, 2007 | HP 610 Color Copier
HP Color LaserJet 2600n Printer Logo
757 people viewed this question
Seeker5211
Seeker5211
