Question about Vestax PDX-A1MKII Turntable
I carnt remove the turntable platter can anyone help
I have vestax PDX-a1S turntables and i carn`t remove the platters. i have tried pulling them but no result can you help me please many thanks.
The platter needs a drop of oil as the platter and motor shaft is a machined fit, Via brass upside down v as the platter will be reversed ie: a A WITH NO LINE . You can place two plastic wedge shaped blocks ,one on each side of the platter with even pressure and work up.
Posted on May 19, 2009
Vestax pdx 2000 platter moves back and fourth
This is the most east turntable ever made. but are the two screws tied ?which keep the platter on it's place , if so unsrenew them and you see the four mounts where the motor is attached with the top deck , can you move the spindle , (where you screw to two screws in) and does the whole motor moves or only the spindle. Case one , unscrew the case and tighten the four screws, case two: bearings deed, buy a new motor.
Jul 25, 2014 | Audio Players & Recorders
Platter is rubbing against sides of turntable, making a grating sound. How can I fix it?
Remove the plater with the two screws and bow the two pieces of metal where you screw your platter on a bit to above. If the ain\'t it , check the screws where you engine is connected with on the inside and otherwise the rottor holder ain\'t straight anymore, so just inscrew the backplate of the motor , heat that shitty glue , which can be a hell to remove and the pieve of the where the rotor spins on , needs a couple of tick with little hammer in the middle , which will raise the rotor and you have more space.... don\'t hit it to hard and only till it\'s straight. gr richard
Jun 21, 2014 | Vestax PDX-2000MKII PRO Turntable
Clibrate pitch Vestax PDX d3S
It's a variable , since it's depended on more parts, but just clean it first and gently turn it until the platter moves correct,assuming you
mean to correct the variable resistor(potmeter) . If the value was everywhere the same, then you don't need a variable resistor:)
Jun 19, 2013 | Vestax Handy Trax Turntable
Hi,my vestax 2300 platter has a slight wobble.i removed the platter and it seems 2 b the motor,can u help?
sliight wobble is normal but if its something you notice i suggest sending it to them to fix it
Apr 28, 2011 | Vestax PDX-2300 Turntable
Does the platter of the vestax PDX-2300 mk 2 fits on the vestax PDX-2300 mk 1?
Hi ezradf ,
i am afraid no it will not fit, the PDX-2300 mk 1 has a bigger fitting then the Mk 2.
Mar 19, 2011 | Vestax PDX-2300 Turntable
How to remove the platter from the turntable?
Take a a look at the platter, see any screws: unscrew them?
Aug 18, 2009 | Vestax PDX-2000MKII PRO Turntable
Pdx 2000 stylus calibration
Hi Misskit , i have a Dual turntable straight arm [Dual is the brand ] maybe you could visit their website and see if there is something similar to yours that you could get some specs from , i think they are still in business they are a German turntable manufacturer . happy spinning
May 24, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Re: Power Problem
More than likely the power transformer fried. If so, it will need to be replaced. You might also want to check the fuse. Some of the PDX units have fuses on the rear (where the RCA cables connect)... some don't. I've also seen some that have a fuse on the inside of the turntable, underneath the turntable platter... some don't. If your's has a fuse, see if it has burned out. If so, just replace.
If not, then the only other thing that would affect power on the PDX is the power transformer, and only a qualified service tech should replace this for you.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
Aug 09, 2008 | Vestax PDX-2000MKII PRO Turntable
Platter not spinning properly
Make sure the platter is seated correctly. Lift it off, and set it back down. Also check to see that there is no debris or foreign matter stuck underneath the platter or where the platter sits.
Check to make sure the platter itself is not bent or warped. Do this by removing the platter (lift up), and then put it on a flat table/surface. Look at it from the side. Is it warped?
Hope this helps
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Jul 24, 2008 | Vestax PDX-2000MKII PRO Turntable
Vestax PDX-A1MKII Turntable Logo
790 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
