Question about Power Acoustik GOTHIC OV2-1200 Car Audio Amplifier
I have a ov2-1200 power acoustik gothic seaiers ... It had worked just fine since i got it. I went to put my system back into my car this summer and my amp will randomly shut off... it doesnt go into protection mode it just completely shuts down...I checked all my wires and connections and even tried a different amp to make sure the prolem was with my gothis series...any help??
  • Perry Babin May 11, 2010
    If the other amp never cut off, I'd suspect that the Power Acoustik amp has a broken solder connection on one of the B+/remote/ground terminals.
  • 578 Answers
Check the load on you spkr and make sure you playing amp in the right mode
Posted on Jun 26, 2009
Power Acoustik amp
First thing to do is check the fuse. If it is still in good condition then you may have blown your amp
You can make sure no wires are touching an also tried wiring in a mode that does not put it at its maximum ohm load.
Dec 14, 2014 | Audio Players & Recorders
I have a power acoustik 0v2-300 2 channel amp i just wanna know can i bridge it
Most amps will show right on the amp by the speaker wire terminals if it is bridgeable.
Good luck !
Jan 28, 2010 | Power Acoustik GOTHIC OV2-300 Car Audio...
How to bridge a 4ch power acoustik amp to 2ch
I had the Power acoustik saphire 4ch and had to do the same thing. Use the Positive from Term1 (spkr1) and Negative from Term2(spkr2). Good Luck.
Nov 26, 2009 | Power Acoustik GOTHIC OV4-800 Car Audio...
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Amp is not putting out, shuts down
you have a bad ground recheck your ground and make sure you have a good one
or the guage of your power wire isnt big enough
May 01, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Power Acoustik
the amp shouldnt even lite up w/o the ground attached.
Jan 25, 2007 | Power Acoustik GOTHIC OV2-520 Car Audio...
Power Acoustik GOTHIC OV2-1200 Car Audio Amplifier Logo
217 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
