Question about Xerox Phaser 8560MFP Laser Printer
Add cryn ink
Error says add cyan ink in 8560mfp
  • Xerox Contributor
  • 185 Answers
The ink may be jammed in the ink loader. Try to re-load the cyan ink chute
Or perhaps the inkloader (848K06380) is defective.
Posted on Jul 31, 2009
Could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
This must be performed following an ink loader replacement.
2. Test the appropriate Ink Melt Heater.
Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
No)Replace the Ink Loader
Aug 03, 2011 | Xerox Phaser 8560MFP Laser Printer
My xerox phaser 8560/8560MFP keeps saying it is out of cyan ink, but all of the ink slots are completly full. What can I do to fix the problem? I have unplugged the printer/scanner twice, also I have taken...
The problem could be with a sticking flag in the ink loader. If you look down the channels where the ink sticks slide you will see a small spring loaded flag, check that it is not sticking in the cyan tube. Check for any stray/broken ink or other debris that might be stopping the inks from travelling.
Alternatively it could be that the ink melt plate is faulty, the printhead calls for ink when it gets low, if no ink is melted into the well, the printhead informs the main board if the main board does not see a fault condition, it will report out of ink.
Unfortunately, the ink loader is not repairable and has to be replaced.
Jan 20, 2011 | Xerox Phaser 8560DN Printer
I have a IR 400 machine. error : E100
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Xerox Phaser® 8560, 8560MFP Cyan...
Print error 09, 005, 40:5069 how do i fix this?
Hi
This error in Xerox 8560 printer occurs when Cyan ink melt heater is on but the ink is not dripping. To troubleshoot this issue please make sure that you are using genuine Xerox ink. If yes then run Clear ISC Fault test to clear the error. The Clear ISC Fault is located in the Internal Diagnostics Function menu.
Also check for broken or wrong type of ink sticks. After this try clearing the fault by running Clear ISC Fault option. If the sticks are also fine then run the appropriate Ink Melt (1,2,3,4) Heater test. If the test fails then there is an issue with the print head.
Daniel Scott
Jun 08, 2010 | Xerox Phaser 8560MFP Laser Printer
Error code 09,035.43:30419 on Xerox Phaser 8560
Check your ink sticks, one of them is most likely stuck.
Dec 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP/N System error 09,038.46:950
Hi mary_ballling:
Here is you problem.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to
Go to Step 3.
Remove any blockage and/or replace the ink stick.Run
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run
Hope this helps
Jul 31, 2009 | Xerox Phaser 8560MFP Laser Printer
Error 09,036.44:41689
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
May 01, 2009 | Xerox Phaser 8560MFP Laser Printer
Magenta Ink cartridge is stuck in Xerox Phaser 8550/8560
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
Scroll down to the function menu, hit ok, scoll to clear isc fault, hit ok.
Mar 31, 2009 | Xerox Phaser 8560MFP Laser Printer
XEROX 8550 DP ERROR Message 09,035,43; 10192
That is a cyan, ( blue) ink stick fault. What is happening is that the cyan ink sticks are not advancing down the ink loader properly.
Open the area where you load the ink and you probably have a cracked, twisted or otherwise stuck ink stick, the code you are reporting specifically refers to the cyan sticks. If you have to remove them, take a screw, a drywall screw is best, and twist it into the sticks and slide it back and out, then replace them or add new ones. But thats your problem.
Oct 29, 2008 | Xerox Phaser 8500/DN Printer
HELP!!! Phaser 8500 Error 09.035.43:28534
That is a cyan ( blue) ink stick count failure.
Look in your ink loader. First just try opening and closing the lid.
Then look for gaps in the cyan sticks. Most likely one is broken, cracked or otherwise jamed in the slot.
If you have to remove them, take a screw and screw it into the ink stick then slide it up the chute and out, then reload.
Hopefully someone didnt try to add or cut up a stick from a differerent phaser.
Thats your problem. Just a stuck cyan ink stick.
Mar 24, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560MFP Laser Printer Logo
327 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
