Not cold enough
How often does the caravan Electrolux Blizzard air con unit need to be regassed. And what is the quantity of R134A in the system as my unit does not chill Jim
  • Anonymous May 15, 2009
    how cold should the airconditional blows
  • 400 Answers
An air con unit of any make should never need to be regassed if initially installed correctly. If it needs regassing, there must be a leak. You would have to find the leak and repair it before regassing, or it would be the same as pumping a tyre with a slow puncture. Generally most simplex systems use around 750 to 800grams.
Posted on May 14, 2009
Need a diagram of how to install a electrolux air con split sistem model sa101 in a caravan please
not a job for diy
get it professionally done by people familiar with caravan construction or you could wind up with a failure of the van when travelling
Jul 03, 2016 | Electrolux Heating & Cooling
I had my air con regassed and it worked fine for a while then now it isnt blowing as cold as it was it has no leaks but the fan doesnt work when you turn it on.does anyone know what the problem might...
If there were no leaks, why did you have it recharged ?
If the system is low it will not build up enough pressure to activate the radiator fan.
Jun 26, 2012 | 2004 Kia Sedona
I have a R410A Inverter Split system that has stooped suddenly and is now displaying E1, what does this mean/ Thanks Lorena
Not 100% sure but an E1 error on a unit which is sourced from the same place as Electrolux air cons, means that the pipe sensor on the indoor unit has failed. You will need to confirm this with Electrolux. They carry a 5 year warranty, so you may be in luck.... hopefully
Jul 16, 2011 | Electrolux Heating & Cooling
Air conditioning not cold enough
probably will need to get the unit regassed.
one way to see if this is the case is by checking the air con reciever/dryer which is commonly placed right at the front under the hood latch. it should have a little window on it that once the car is runnung and aircon on should not change, but if it is running out of gas there will be bubbles that will pop into the window indicating that the gas is low and needs to be topped up.
Jul 15, 2011 | Air Conditioning and Heat for Lincoln MKT
Air con fan works but no cool air the compressor doesn't appear to start
It may need regassing, air con runs out after a while as its 2005 it most likely needs to be regassed/refilled!
Jan 14, 2010 | 2005 Ford Futura
1997 jeep desiel air con not cold took it to a air con place they regassed it still doesnt work they seem to think it might be electrical
If they filled the system back up and the clutch on the compressor is engaging then your system should be pushing the R-134 around. If it is not cold you probably have a bad expansion control valve. This valve regulates how much and how fast the R-134 passes through. If it is not working correctly that is probably the cause.
Dec 03, 2009 | 1997 Jeep Cherokee
Is R407c compatible with R134a
no absolutely not! Those kits are also more trouble than they are worth if anything at all is not right in the setup. Its worth going and having it done proper, and its not too pricey as long as you phone around enough.My shop in NB charges $10 per pound and a flat rate for labor depending on vehicle. You will burn out the AC in about a month on the wrong refrigerant, they have r34 in r407 as straight up r407 is no longer legal as pure.
Aug 16, 2009 | Beam Industries Sunbeam 1349705 Air...
Air blowing out of Air Conditioner but it is not cold!
when you regassed did you check for leaks and could you see flow through the sight glass. if the answer is yes to both i would say the compressor has had it.
Jun 20, 2009 | 2001 Mitsubishi Diamante
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Aug 27, 2008 | Electrolux Refrigerators
Heating & Cooling Logo
423 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
