Question about Panasonic AG-DV2000 Mini DV VCR
DV tapes will not load
I have a Panasonic AG-DV2000 Mini DV VCR and recently the full size DV tapes quit loading.  The drawer tries to close but stops short of closing and opens back up.  Mini DV tapes load fine but the full size tapes won't.   Any ideas?  thanks
[email protected]
  • bejaytee Dec 11, 2007
    I have the same problem EXCEPT, the carrier will load the mini dvs ok, just not the full size ones. Tries to drop down but comes right back up. Any idea where to look? Thanks.
This isn't the most professional solution but I stumbled upon it and it works most of the time.
I was dubbing tape to DVD via a set-top DVD burner. I had the DVD burner stacked on top of the AG-DV200. As a result of operating both at the same time, the DV deck got really warm. By chance and frustration I attempted a full size tape again and learned that the tape drawer will accept Full-size tapes when the deck is warm. I'm assuming the increased temperature loosens up some of the grease.
Not perfect... but definitely got me out of a bind and some expensive repairs.
Posted on Aug 24, 2009
Mine was broken in the same way (unable to load DV tape). Turns out that inside the left side of the tape drawer there is a white plastic piece that has a pin that sticks out and engages the mechanism that moves the tape reels. This all happens based on the lever on the left front of the tape drawer. Well there is a small spring that operates all this and in my case there was a black plastic pin that is part of the drawer that broke off (frankly a very weak link in a $2k machine). I was able to manufacture a new pin but it was very, very difficult. I would say that for most folks you need the new drawer.
Posted on May 07, 2009
  • Bruce Dixon Sep 09, 2010
    My AG-DV2000 has the same symptoms. Large tapes won't load. The tray closes, you can hear the tape drop down and pop back up right away. The cassette icon on the front panel never lights up because the reel tables are in the small position and the tape is still at the top of the elevator. I decided to order panasonic part VXA5991 for about $50. It's just the left side of the tray, rather than ordering the whole assembly. It would be much easier to replace the whole tray, but also more expensive. I can't see the "black plastic pin" mentioned by gwbarr, but I am pretty sure it is inside the left (Supply reel) side of the tray. I have a second unit with the exact same problem, so if this works, I'll be doing it a second time.
    BD in Arlington, VA
I am experiencing the same exact problem with my ag dv2000 and after reading thes comments im a little confused ...so u guys are saying 2 things it could be the grease is hardened or its the cassete it self? i started my current job working with video and my ag 2000 since i started a year ago ... always needed a little help getting the dv cassete loaded. so i would just give it a little push with my thumb. the the dv deck has sat for the summer and when i tried to use it today 1. the tape wouldnt load and the mechinism that pulls the film reel out dosent even turn on when the dv tape is inside???when it started to do this the monitor that it is connected to said that i have the wrong tape inserted???wtf! lol Please give me some guidence otherwise i might have to go the shitty route and take this aged item to a repair shop.........................:-(
Posted on Aug 29, 2008
The problem you are having is caused by the grease that is used to move the reel positioning mechanism has hardened. Once the grease hardens the reels can no longer position properly. The grease needs to be removed and replaced. Do not remove the cassette assembly, only remove the top plate. Also check the pinch roller grease, make sure the pinch roller moves freely.
Posted on Dec 26, 2007
    Champion:
  • 221 Answers
The "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure.
Posted on Oct 30, 2007
2 Suggested Answers
SOURCE:
  • 221 Answers
SOURCE: Panasonic AG-DV2000 Mini DV loading problem
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure for the inexperienced.
Posted on Oct 26, 2007
When attempting to load a tape into the AG-DV2000, the cassette door does not open and the display reads F07.
i had the same issue with my ag-dv2000, a fun problem to solve without a service manual. first verify we are dealing with the same issue.first open hopper fully and apply power. you should get an f06 error(failure to close in required time), now close hopper and apply power, you should get a f07 error (failure to open in required time). if this is the case the bad part is the motor drive ic. ic 1 on the motor drive board mounted to bottom of dv mech. it is a 10 pin ic labeled xra6887. i have not located a source yet but you can confirm the chip is bad by replacing it with ic6502 on the same board. if you put the bad chip in place of ic 6502 you will ground power supply and will not have power, leave it out. it controls threading motor, not needed to verify problem. the door should work now. dont put in a tape untill you replace bad chip. if you find the panasonic part number for this part please post it. happy desoldering!
Sep 16, 2011 | Panasonic AG-DV2000 Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
the problem of your player is the mechanism to dv tape slut(not mini dv)...it need to calibrate or to tune up...only can fix this is a qualified technician....
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
My panasonic AG DV2500 mini dv VCR hates loading and ejecting.
this loading problem in the AG-DV2500 is caused by a defective cassette housing. list price from Panasonic is about $375.00.
Oct 15, 2009 | Panasonic AG-DV2500 DV/Mini DV VCR
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
Problem with playing large dv tapes
I am very familiar with these decks and I repair them. Contact my business Waveform Audio Video, Martinez, California. Email: [email protected]
Paul
Oct 15, 2008 | Panasonic AG-DV2000 Mini DV VCR
DV Deck not loading tapes...wtf
most likely problem is a defective cassette housing. good service tech should be able to handle this with no problem.
Aug 29, 2008 | Panasonic AG-DV2000 Mini DV VCR
Error F03
F03 is a loading mechanism error. look for something obstructing the loading arms in the mechanism - a label from a tape, a piece from a broken cassette, etc.
May 08, 2008 | Panasonic AG-DV2000 Mini DV VCR
Oct 11, 2007 | Panasonic AG-DV2000 Mini DV VCR
Stuck tape
If you haven't already done so, don't get overly forceful to avoid bending or breaking something. Often the cassette carriage mechanism is gear driven, and by moving the gear one direction or the other will unload the tape. You may need to disassemble the machine further to gain access to the drive mechanisim. Sometimes the carriage mech. can be entirely removed from the VCR by removing the attachment screws. Other times, these screws are made inaccessible by the tape itself. Look down on the right side of the carriage. If you do remove the carriage, mark the gear positioning first! as the gears must be positioned back exactly as they were from the manufacturer. You might need to employ the services of a technician if things are complicated.
May 26, 2007 | Panasonic AG-DV2000 Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR Logo
438 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
