Question about IBM ThinkPad T23 2647 Notebook
Computer monitor shutting down
I have an ibm thinkpad t2647. my battery needs to be replaced as it does not hold a charge and have been using adapter instead. initially, the computer worked fine. Recently, the computer shuts down after 10 minutes of use and battery does not stay charged. is the shut down due to the use of the adapter? is it a new battery that is needed?
  • 1 more comment
  • speakingspir May 09, 2009
    just did..will see how long it last...also has z surrounded by circle on keyboard and a blinking barrel (first and last light). also changed settings of monitor in control panel and powered down and back up but light still on.
  • Frank Zhang
    Frank Zhang May 11, 2010
    so when the laptop power down but some lights on or blinking?
    whst is beez like one long three short or other?...
  • Frank Zhang
    please take out the old battery using adapter power on the laptop see how long to use?
Lenovo thinkpad plugged in not charging is there a problem
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the IBM ThinkPad X40 power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Jan 01, 2013 | IBM Lenovo ThinkPad X40 Notebook
Tip
IBM Laptop Battery Power Saving Tips
How to try to extend the battery life are much concerned by many laptop users. Utilizing some small skills and minimize unnecessary waste of battery during the using process can make you full use of your laptop battery power.
The engineers of IBM personal computer business division give vast laptop users some good suggestions here to ensure that you can maximum extend laptop battery utility time. Therefore, it will improve your work efficiency; let you enjoy mobile office work and entertainment pleasure without limits.
IBM batteries on sale :
IBM thinkpad t40 Battery £ 37.52
ibm thinkpad t41 battery US $ 41.24
ibm thinkpad r60 battery. US $ 71.27
IBM ThinkPad T60 Battery £ 38.51
* Turn down the brightness of the screen. At the same time, although IBM ThinkPad laptop keyboard is equipped with lights, ThinkLight, but in order to save power, it is better to turn on it when under darkness conditions.
* When not using the wireless receiver device, turn it off please.
* Some users like opening CD or DVD to play music anytime, the power of battery will flow away quietly along with the music playing. Suggest everybody turn on the music only under the situation that they do want to enjoy the music.
* When the battery during using process, try to fully charge and discharge the battery.
* Try to avoid using it under high temperature and low temperature, for example, when you enjoy sunshine on the beach, please don’t leave your laptop in the car to enjoy SAUNA.
* Use proper AC adapter for your ThinkPad laptop.
* Use the IBM ThinkPad battery Battery MaxiMiser management software you select the most suitable for the extension of the power program.
* Use the IBM ThinkPad battery management software – Battery MaxiMiser, select the power extension program which suitable for you.
* Setup the standby time of monitor, hard disk and system sleep time, because it is no need to let your laptop still running at full load when you are at non-working stage.
* Under the Intel SpeedStep technology effect situation, the processor based on the current load situation adjusts the speed automatically to save battery power overall.
In fact, the laptop battery is a spiritual guy, after got expert advices, please treat it properly, it will bring you to enjoy a better mobile life.
battery info via:
http://www.sales-battery.com
http://www.global-battery.co.uk
on Jun 04, 2010 | Computers & Internet
My battery is not charging. The charge light keeps flickering orange once i plug in the charger but it never charges. The computer switvhes of the moment i unplug the computer. what can i do?
Try to perform power drain first. Please follow procedure below.
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30secs
Put the battery back in
Plugged in the power adapter
Turn ON the computer
If same issue will happen after this troubleshooting. I suggest you purchase a new battery. If you unit is still under warranty, you may call IBM tech support for battery replacement.
May 31, 2010 | IBM ThinkPad T23 Notebook
My ibm laptop contionusly beeps and says power scource is battery,when i press esc, it boots normally and shuts down in about 15 mins to half an hour
Either:
A. Bad battery
Or
B Bad power supply.
Sounds like the battery isnt charging correctly , the beeping is warning you it is running out of power.
Take the battery out , and boot normally with the ac adapter.
Does it work?
If yes, Get new battery. about 70-90 dollars.
If no. Get new ac adapter. 20-40 dollars.
links to parts
http://www.nextag.com/ibm-a21m-battery/search-html
http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=ibm+a21m+ac+adapter&x=0&y=0
http://www.laptopuniverse.com/product/02K6496-Laptop-Notebook-Power-Supply-AC-Adapter-For-IBM-Lenovo-Thinkpad-A21M-16V-60W-Part-02K6496/LU/36124/productDetails.html
Mar 03, 2009 | IBM ThinkPad A21m 2628 Notebook
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
Battery indicator on even after turn off the laptop
Reset the battery.....remove battery from system...boot while your adapter is plugged on....shut down..reinstall the battery......
if this doesn't help..
go to Control Panel>>>>>>Power Options and view setting ..........what does the system do after being switched off options
keep me posted
Cheers
Nov 17, 2008 | IBM ThinkPad T40 2373 Notebook
IBM T23 Thinkpad battery does not charge
If you have some electronic skills and are not afraid to open up your laptop then I might have a solution for this. It could be a known problem in T23 where one component is loosen from the mainboard and in that case it can be fixed with a soldering iron. Other possible cause is blown fuses. But to confirm this you have to remove the keyboard and do the check.
Nov 14, 2008 | IBM ThinkPad T23 2647 Notebook
Ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Nov 05, 2008 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
X41 Tablet PC the battery shows good but computer will not work
Some times a battery can pickup a dead short, and even though it shows a charge it will not work. The other possibilty is the power management chip on the mother board. This chip allows the computer to charge the battery and switch from battery to AC. (Right now I have a Thinkpad that will only run on battery, bad PM chip) Try replacing the battery first, if that doesn't work, then unfortunately the motherboard will have to be replaced.
May 24, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T23 2647 Notebook Logo
103 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
