Question about Canon PIXMA MP600 all-In-One InkJet Printer
Service error 6000
This error code is shown on LCD screen and on the computer screen.
    President:
  • 987 Answers
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
Posted on May 10, 2009
Il affiche printer error service call6000
problem is with fuser,Code Error indications Contents
Check procedures/corrective measures
6000 Fuser unit error
Yes
Yes
Yes
No
No
Turn power switch off,
and remove power
cable.
Detach connector CN4
on power supply unit.
Detach connector CN1
Measure resistance
between pins 1 and 2
of the detached
connector.
Replace fuser thermistor.
See page 1-6-25.
Replace thermal cutout or
heater lamp. See page 1-6-
26 or 1-6-22.
Replace bias PWB (K0009)
or high voltage unit or power
supply unit. See page 1-6-13
or 1-6-12.
Open (infinite)?
No
No
Open (infinite)?
Measure resistance
between pins 1 and 3
of the detached
connector.
Replace harness
(2FM2601) between engine
PWB (K0010) and bias
PWB (K0009).
End.
Yes
No
Replace engine PWB
(K0010). See page 1-
6-9.
"6000" error
shown?
"6000" error
shown?
START
Feb 03, 2014 | Kyocera Mita Fs-1016 Mfp Multifunction;...
Error code (-6000,-83)
1.. Your solution depends on what action you were taking when the error occurred. Please choose the appropriate selection.
You are opening your company file
You are storing your company file on a Windows server
You are storing your company file on a Linux server
You are restoring your company file
2.. Intuit recommends more than one solution for this problem. The first solution may solve your problem, or you may need to try all of them to resolve the issue. For best results, perform the solutions in the order shown.
Solution 1: Change the extension if the restored file extension is .qbm or .qbw.adr instead of .qbw
Solution 2: Check for problems in your file name and file path
3.. You are creating a back up
Create a new File Folder on the root of the C drive.
Create a backup and save it to the newly created File Folder.
for more help visit
QuickBooks Tech Support
Feb 12, 2013 | Intuit QuickBooks Pro 2008: Windows
Canon mx357 code error 6000 soultions
sir i have a canon pixma mx357 printer. it gives a code of 6000 (printer error has occurred turn off power then back on again. if the problem persists see the manual) shown in the window. will u please give me the suggestion to repair the printer. my e mail id is s_kalivarapu@yahoo.com
Jul 04, 2012 | Canon Office Equipment & Supplies
Install cd for web cam vx-6000
Hello. You can download the software for your VX-6000 by accessing this WEBSITE.
Note that the driver above is available only for Windows XP.
Enter the code shown and click on "Download This Driver for Your Device from Open Drivers" then download the file. Save it to your computer, run and install it properly!
For Vista, you can try this WEBSITE. (Also enter the code shown and download the software)
I hope it works!
If you have any other questions, please leave a reply!
Thank you for using FixYa!
May 28, 2011 | Microsoft LifeCam VX-6000 (68C-00001)...
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Problem with Code 6000
Hello, according to another expert at fixya:
"Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board. "
Jul 29, 2009 | Canon MX310 Office All-In-One Printer
The display on my inspiron 6000 in jumpy at the bottom 1/3 of the screen. no evidence of any damage to case or screen. Just started with a black line and now jumps around and has white lines in the bottom....
Generally the problem is caused due bad LCD inverter cable. Kindly run the LCD diagnostics
How to Run diagnostics
1. Shut down the computer
2. Disconnect the AC adapter and Battery
3. Press the power button for 10 sec.
4. reconnect both AC adapter and battery
5. Press FN key+ power button
6. Follow the screen prompts.
If the LCD problem is shown in diagnostics your screen would have to be replaced.
Thanks for using Fixya
proton
Jul 27, 2009 | Computers & Internet
Error code 6000 is showing on the lcd screen how fix problem?
what model printer? 6000 codes are usually related to the fuser section.
May 06, 2008 | Office Equipment & Supplies
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
293 people viewed this question
old marine
old marine
