Will not pump water out
My washing machine has done a full wash but now will not drain the water?? My dad said could be a blocked filter and to just rinse it but i cant find one?? Hotpint WD440
  • 38 Answers
My grandmother had the same problem. Lets see if it's the same one. Maybe, your water filter is clogged. Washing machines have a water filter right before the water comes out. Try cheking that out, maybe it's clogged by hair or something like that.
Posted on May 09, 2009
When reach to rinse water was not drain out -
THE PROBLEM MAY BE QUITE SIMPLY THE WATER PUMP FILTER BLOCKED, OR THE PUMP IS SEIZED UP'
can you hear the drain pump running, if you can then switch off machine and remove and clean drain filter not forgetting if you remove filter with machine full of water it's going to flud floor so fit a tray under filter and unscrew and drain a little at a time. g luck
Nov 13, 2016 | Washing Machines
E5 error on Onida washing machine Need solution
5E. This means the washing machine has a "water drain error". It's basically timed out on empty, it's tried draining out the water for 10 minutes and the water level still hasn't fallen below a specified level (or at least it thinks it hasn't). This error should be reset by pressing the Start/Pause button though if there is a fault it will need fixing or the error will just return.
A washing machine not emptying the water can have various causes as can a washing machine thinking it hasn't drained the water because it's possible that the signal telling the machine that the water has gone can sometimes not be triggered if a fault in the pressure system prevents it.
To troubleshoot this problem the first thing to check is the pump filter, which could be blocked. I have extensive advice on diagnosing pump faults here Washing machine won't drain water (stuck full of water) ' Faults on pressure system
May 17, 2015 | Washing Machines
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 26, 2011 | Samsung Washing Machines
I was washing today and at the end of every wash tere was a code of f18 flashing on my screen .what should i do
F18 means pump is blocked or broken, clean filter first, no result change then you have to change the pump.
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins.
Jan 06, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
Water will not drain cannot open door
The possible problems here are blockages or pump failure. Blockages are the more likely explanation but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting (if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from the pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops).
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front panel. If your washing machine has a water pump filter and a filter drain hose you should be able to drain the water from the washing machine into a bowl without moving the washing machine. Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain into a bowl. It's likely to be painstakingly slow but at least you don't have to try and pull out a heavy washing machine full of washing and water.
If your washing machine doesn't have a pump filter, or it has a pump filter but no draining hose then it's a bit trickier. To drain the washing machine, you will need to remove the drain hose from the drain pipe at the back of the washing machine, and lower it into a bowl or bucket. Many plumbers now plumb the drain hose into the U bend directly under the sink instead of a separate waste pipe at the back of the washer. If yours is connected directly to the u-bend, you can usually unscrew it easily. Remember though, that with the pipe disconnected from the U bend, any water poured down the sink will flood out into the cupboard until the hose is reconnected.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If none is found, sometimes a blockage can occur in the plastic connector that the drain hose is connected to at the sink end (if connected this way)
Once you have the drain hose disconnected and lowered into a bowl or bucket the water should siphon out as long as the pipe is low enough. You are likely to get several bowls full of water from the washing machine. If little or no water comes out then it may be blocked by an item of clothing like a sock and it won't be possible to empty the machine this way or it is going to be a long process.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin. Keep the pipe low down and in the bowl or bucket and put the washing machine on a spin only program. Note, this last step is not strictly necessary as once drained, the door should open. However, you might prefer to try to spin a few more bowls of water out.
Clearly if you put more water into the machine it is likely to fail again until the fault is rectified but these instructions should at least get the clothes out.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines have a filter inside the sump hose which gets blocked. Finally, the pump itself can be faulty.
Dec 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
MY WASHING MACHINE HAS STOPPED 28 MINUTES THROUGH THE WASH CYCLE. ITS SHOWING UP E20 ERROR. ITS FULL OF WASHING AT THE MOMENT
Hi!
Error E20 means there is a problem with water draining. Please check the drain hose which may be kinked or squashed or the drain pump may be blocked. Another possible cause is totally blocked filter which is required to be cleaned to resolve the issue.
Thanks for using FixYa and revert for further assistance.
Thanks
Rylee
Jul 18, 2009 | Zanussi ZWF1430W Front Load Washer
Washing machine not draining water during washes
hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
My machine will not pump out the water
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front. (Some Hoover & Hotpoint washing machines do not have any customer accessible pump filters - if in doubt it will tell you in the instruction book).
Jul 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
