Question about Garden
Troy Built gas trimmer will not prime.ill not prime
I have a tb25cs gas trimmer. It will not prime. The bulb pumps air into the gas tank, but no gas to the carb with the tube off of the carb. When I put the tube back on the carb, the buld stays collasped.
  • 38 Answers
To me it sounds like your line is clogged. It pumps towards the tank but not towards the carb. Open it up, and check your lines out, if it's clogged it could be a little too much oil (just saying if it smokes alot when it's on).
Posted on May 09, 2009
Troy built 90bc weed eater will not prime after new fuel lines
Could there be the possibility that the lines may of been put on the wrong way i would try swap them around first, also the primer bulbs do not like air make sure all the fuel lines are all on tight and that there is heaps of fuel in the tank
Jul 30, 2014 | Garden
Troy built trimmer fuel lines
normally the one nearest to fuel pump /primeer bulb is the inlet and the lower one is return
WHY can't you just connect hose to one and pump primer bulb to see what direction it goes ?
Jul 28, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
How to replace troy built tb25cs primer bulb?
The primer bulb has two clips that fit into a slot. You will have to squeeze both clips to pull it out. Make sure you remember which fuel hose went on each nozzle of the primer. There are two nozzles. Make sure you put the fuel line back on the same way. The part # for the bulb if you need it is a Walbro 188-512-1.
May 27, 2014 | Troy Bilt Tb70ss Gas Trimmer
The primer bulb on my Troy-bilt TB20CS will press in but it doesn't feel like it's pulling in fuel. Earlier after filling the gas tank, I noticed a little gas was leaking, and saw that the tube...
Or it could be like mine. I turned it upside down to take the cover off (Troy Bilt) to clean the air filter. Put it back together and the primer won't fill. Also it looked like air was coming into the bulb from the carb. Weird, since it was filling just a minute ago. Turns out the fuel lines in the tank were dry rotted. When I emptied the fuel tank, bits and pieces of fuel line came out along with several washers and a weight that goes on the end of the hose. Looking inside I saw a hose not connected to anything. Pulled it out and it came out in pieces (kept breaking when I'd grab it). That's why it's not connected to anything! Also why it won't prime or start. Probably also why it was getting to where it didn't run very well, and only on the A choke setting. It would cost almost as much to fix as to buy a new one. Bummer. For $90 though, if lasted five years. Maybe if I change the lines earlier on the next one I can even get more life out of it.
Jul 09, 2011 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troybilt trimmer primer bulb collapses. it will start occasionally but will only run a few minutes.i have replaced the primer bulb and gas lines and still have the same problems.
it should have a small vent in the fule tank cap if its blocked the primer bulb will be sucked in as the fule pump can **** any fule from the tank
check the tank cap first,,,,,
Aug 08, 2010 | Troy Bilt Tb70ss Gas Trimmer
The trimmer will not start, the prime bulb sticks when pressed, gas is not flowing through the carburator
Many things can cause the unit not to start (see www.zama.com) for troubleshooting their carbs and what causes a no-start condition. If the purge/prime bulb is sticking..there could be a bad fuel filter in the tank with a side condition of bad fuel lines...ruining the vacuum action needed to operate the bulb correctly. It helps to understand (and you may) just what the purge/primer bulb does. It "pulls" fresh fuel into the body of the carb by "pulling" out any air and old fuel in the body of the carb...then it "pushes" this air/fuel mixture (with new fuel lines you can see this) back to the fuel tank. ...and it sounds like you need new fuel lines also.
Jul 14, 2010 | Troy Garden
Primer bulb doesn't pump gas
Does the primer bulb pop back out or does it come out slowly? Is the inline hose in good shape or has a crack where it can **** air in? Did you check to see if the diaphgram in the carb is pliable or is it paper-like and needs replaced. Or your carb could be stopped up.
Only one problem..I can't think of any weedtrimmer that has an inline fuel filter. They are usually located in the gas tank.
Jun 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Jun 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
226 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
