Question about Car Audio & Video
Tow bar electics
I have a 2008 vauxhall zafira, it has a towbar fitted but its not connected to the cars electric i.e indicators, brakes etc.i have a diagram explaining the wires from the towbar but i cant find a diagram for the corrisponding wires they need to connect to in the car...
  • 33 Answers
Hi, I don't know whether you have sorted this or not but you MUST NOT connect directly to the cars lighting system, it will assume that there is an overload and switch the circuits off. You must use a bypass relay system of some sort, or preferably a vehicle specific wiring kit which will either plug directly into the REC (fuse box) in the left rear cubby hole in the boot or if you don't have the REC then a different wiring kit plugs into the lamps and has a towing interface with it. If you are not sure what you are doing then best contact your local towbar specialist.
Posted on Jul 21, 2009
What is the maximum weight caravan i can tow with a vauxhall zafira automatic 1991
Has long has you don't go over the kerb weight you should be OK.I think the car should be able to tow about 1100kg.
Apr 22, 2015 | Vauxhall Cavalier Cars & Trucks
Fitting instructions for a great wall 240x 2012 wagon towbar
fitting tow bars now require a compliance plate to keep the vehicle road legal. I would suggest that you use the services of a tow bar fitting shop and they will supply all the wire connections and the compliance plate when done.
Feb 25, 2015 | Cars & Trucks
2004 series 3 BMW 316i fitting a Towbar mainly how to remove rear valance
you shouldnt need to remove the rear valance to fit a towbar ,i would suggest you contact a authorised towbar fitting workshop as it is not permitted to fit a towbar yourself ,it has to be done by a company with the correct authorised dealership as the towbar has to be certified with a europeon certificate of homoglonation and a plaque .then vehicle has to be presented at the vehicle inspection station for conformity .Then the paperwork of the vehicle changed to show its fitted with a towing hitch and a fee paid for this service .alicantecoli_18.jpgalso the electrics have to be connected by a auto electrician as every annual vehicle inspection the electrics are tested as well where a towbar is fitted .
May 29, 2011 | BMW 318 Cars & Trucks
I have all relevant diagrams and wires for my tow bar but dont know where to connect wires or what wires too connect my towbar wires too, can any1 help me. its an almera
Hi There it may be easier to trace the required wire from each light cluster and splice in the towbar electrics rather than follow a hand book wiring diagram ie; pin 1 Yellow L/H direction indicator. go to left hand cluster and locate left hand indicator wire, stip back the tape binding enough so that you have enough to play with and then splice in the Yellow towbar wire and continue onto the next wire on the list. Good luck
Apr 29, 2011 | Nissan Altima Cars & Trucks
The on car computer tells me I have a stoplight out when I indicate and when I brake it says that the indicator is fulty. all bulbs have been changed to no avail.Car is a 407 but did not have that option.
any other electrical faults? any aftermarket electrical equipment been fitted about the same time as the light problems?(phone chargers, Sat nav',  etc.-remove temporarily to make sure they are not interfering with operation of electrics) are you sure all the bulbs fitted are the correct type - a twin filament bulb fitted where a single should be perhaps? maybe remove any bulbs fitted recently and see what happens. poor battery condition/low voltage/dirty connections at battery or earth wires can cause electrical problems like this. give more details of vehicle - year, model, spec etc. and say if problem is intermittent or every time you use the brake +/or the indicator. if you have a tow bar and trailer light socket fitted to it water entry into the socket could be the problem.
Mar 05, 2010 | 2005 Peugeot 405
All stop lights not working just fitted towbar worked when first fitted
u have shorted out the brake lights, disconnect the tow bar and replace the fuse, the tow bar wiring is shorting out
Sep 04, 2009 | 2004 Land Rover FreeLander
I need instructions on how to fit the electrics to a vauxhall astra estate 2002 towbar,i have had to put other car make in boxes as it does not show astra estate
You can wire directly into the loom behind the left hand light unit.
The colours are L/H Indicator = Black White, R/H Indicator = Black/Green, Fog = Black/Blue, Brake = Black/Yellow, L/H Tail = Grey/Black, R/H Tail = Grey/Red, and Earth to be bolted to earth point here to.
Jul 04, 2009 | 2002 Volkswagen Eurovan
Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Jun 03, 2009 | 2006 Subaru Forester
Vauxhall zafira towbar wiring diagram.
what make of towbar wiring kit was fitted ? You can get a Whitter grey (S) fitting kit but this connects to their own black (N) wiring kit I would think any supplier of the N wiring should be able to supply a S kit.
JB
Nov 07, 2008 | Car Audio & Video
Volvo V70 2001.. Plugs For Towbar Electric's??
You can get an adapter that fits in to the 13 pin socket that give you a 12N socket, easily available on E-bay
http://cgi.ebay.co.uk/13-to-7-Pin-Adaptor-for-Euro-Style-Towbar-Electrics_W0QQitemZ110303426204QQihZ001QQcategoryZ36631QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I have one for my car and it does the trick
Sep 30, 2008 | 2001 Volvo V70
Car Audio & Video Logo
857 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
