Question about kawasaki 1152 System
No sound when watching tv.
Need to know if this system will have sound only if i am playing a dvd or a cd.THANK YOU FOR YOUR TIME.
  • 661 Answers
I think that all depends on how you have it set up, I'm guessing that you have the speakers connected to the DVD player,  however I'm not sure if you have any audio cables running from the TV to the DVD  (required if you want this for sound from your TV), I'd check your configuration, as it sounds like you have not got this set up right.
Posted on Oct 11, 2007
SOURCE:
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
Dvd
sounds like your memory is insuffiicient..can you open your system settings, and let me know how much memory you have on board?
Apr 28, 2008 | HP Compaq Presario V2000 Notebook
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
I can't get my coby DVD 937 to play sound while watching tv. It works fine while playing a DVD or CD????
there should be an input line of just audio cable hookups (one red and one white) that you have to run and an output cable from your tv audio output of just red and white. make sure the tv says output or line out and the surround sound system says input or line in
May 05, 2009 | Coby DVD-937 5.1 Channel DVD...
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
The sound suddenly cut out for my Bose 321 GSX system
I now have this same problem. Would like to know if there is a fix or if my system is just failing for good
Apr 09, 2009 | Bose 3 2 1 GSX System
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
Audio problems
Did you connect both left and right RCA cable to aux1 forTV?Are you playing CD through your dvd player?
Also,double check your connection from your speakers to subwoofer.
Feb 27, 2008 | Teac PLD-2200 System
kawasaki 1152 System Logo
122 people viewed this question
Top kawasaki Audio Players & Recorders Experts
Marvin
Marvin
Tom Chichester
Are you a kawasaki Audio Player and Recorder Expert? Answer questions, earn points and help others
