Question about Amana Refrigerators
I have an Amana TC18HW. During the defrost cycle the freezer water doesn't flow properly and accumulates in refrigerator. External drains were checked and they appear to be clear. Rear cover removed on freezer and evaporator coil had minor ice build up. We cleared it (with a hair dryer), but the problem still exists. We also tried different settings on the frig and freezer energy cycle switch, and this didn't appear to help. Any help would be appreciated! thx, june and ed
mikedurland
  • 481 Answers
SOURCE: Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Posted on Jul 18, 2008
SOURCE: Haier model# HTQ21J*SS freezer ices up with melted water, not draining
I have the same problem. I pulled off the panel inside the freezer and the motor fan wont move and there is black soot all over like there was a fire and it has a burned up smell inside.
Posted on Sep 22, 2008
SOURCE: Freezer Drain Clogged
I had to remove the shelves out of the freezer then removed the plastic casing located in the side rear, this will expose the cooling cords, underneath the cords is a medal drip pan, I removed the single screw and removed the medal drip pan this gave me access to the drain, I used hot water which seems to have cleared up problem.
Posted on Jan 11, 2009
  • 51 Answers
SOURCE: Plugged defrost drain line in KitchenAid Refrigerator KTRS22KHBT00
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
algae, bread ties andf other thing mysteriously get in there and clogg it
Posted on Jan 13, 2009
  • 358 Answers
SOURCE: water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Posted on Apr 08, 2009
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
The freezer frosts and ices up so bad it plugs the holes that cool the refrigerator. Then this morning there was a puddle of water in front of it
Hello and Welcome to Fixya,
This is one of the most common problems in most of the refrigeration appliances. What’s going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Unplug the refrigerator and pull everything outta the freezer, and I mean everything.
  • Remove the bottom panel inside the freezer so you can see the condensate trough in the back of the freezer.
  • Notice that the condensate trough is filled with ice– all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed– don’t start hacking at it with an ice pick because there are chances that you’ll just end up puncturing the evaporator and you’ll turn a simple, inexpensive repair into a majorly expensive one.
  • Use hot water to drain all the frosted ice that is visible.
  • Re-place all the units removed during the process.
  • Once all the ice is cleared away and the condensate drain opening is cleared, you are done.
Best of Luck,
Please do rate my solution, If found helpful.
Regards.
Jan 25, 2010 | Haier HTQ21JAAWW Top Freezer Refrigerator
Water leaking from freezer
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle.
May 18, 2009 | Kenmore 64802 Top Freezer Refrigerator
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
I have a whirlpool refrigerator and it seem to be leaking from
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Mar 24, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Whirlpool frig model -et9fttxlq11 serial-9m5110756 inside at very back water comes out of this opening
Your issue is;
"whirlpool frig. model -et9fttxlq11,serial-9m5110756
inside at very back water comes out of this opening"
Thank you for providing a valid model number!
This link shows exploded view of your model.
http://www.repairclinic.com/0100_2.asp
Water can leak from these areas:
    Please show your appreciation by rating my solution.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jul 24, 2008 | Refrigerators
    Freezer leaks water!
    luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
    Dec 21, 2006 | Amana ABB1927DE Bottom Freezer...
    Refrigerators Logo
    63 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Sal De
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
