Question about Adtran ESU LT Modem
Adtran problem I have the adtran connected to a micom box on port A1, and the port on the micom is constantly flashing with no connection to the other end.
    Problem Solver:
  • 8 Answers
Try repalcing ethenet cable if that does not reslove issue either there is an accumulation of dust in the port or the port has gone bad.
Posted on Oct 19, 2007
How would I connect my acer a1 830 to to my tv to watch showbox ... I was told i could use a micro usb to HDMI adapter to do this and cannot figure it out....
No, the A1-830 doesn't support MHL (micro-USB to HDMI). So the micro-USB to HDMI adapter will not work. The tablet's USB port will only support connecting to the charger or a PC's USB port. Here's a list of known MHL devices: . The previous model (A1-810) had a micro-HDMI port that could connect to a TV's HDMI port with the appropriate cable. You might be able to use the AllCast app and a Roku or FireTV box. You will need to upgrade to the Premium version for any files longer than 5 minutes.
The other way to mirror content from the Iconia A1-830 would be to transfer it to your computer. Then send the file to the TV via Plex or SmartShare depending on the file and your TV. If you can upgrade the tablet to Android 4.4.2 or higher, then a ChromeCast will let you mirror content directly from the Iconia A1-830. This will require steps that can make the tablet unusable (research rooting an Android device).
I wish that I had better news for you. Unfortunately, even if you have a TV with a USB port, it probably will not access the files on the tablet. (Many only support FAT32 or NTSC file systems.)
Jan 25, 2015 | Acer Iconia A1-830 Tablet - 16GB
How does and Atlas 550 split to analog
The Atlas 550 is modular, and can break out the 23 channels as BRI or FXS. Since you want 23 analog lines, I presume you want regular 2-wire phone lines (aka, FXS lines). The you that by using 3 "Octal FXS" modules (8 port modules) in addition to the T1 module.
Read more here:
Nov 21, 2011 | Adtran Atlas 550 (4200305L3) Multiplexer
How do i connect my cable box to my tv
Connect the coaxial "Cable In" cable to the "Cable In" port on the back of your TV cable receiver box. Make sure your receiver box is not plugged in yet. 2 Take the TV audio/visual cable, and connect the red, blue and green ends to the corresponding color "Cable Out" ports on the back of your cable receiver.3 Take the other ends and plug them in to the red, blue and green ports under "V1" on the back of your TV.4 Take the audio cord with the red and white ends, and connect them to the corresponding color ports of "Audio Out" on the back of your cable receiver; then, connect the other ends to the corresponding color "Audio In" ports on the back of your TV.5 Turn on the power of your TV cable receiver box first. Allow it to run through the boot sequence. When you see the time appear on the front of the cable box, you may turn on the television and check your signal.
  • Oct 13, 2011 | Televison & Video
    My modem keeps constantly disconnecting,slow,and the NAT type is moderate which is not good for online gaming, i need to fix this
    Try to perform hard reset of your modem. Reconfigure the settings and make sure that they are correct. To speed up your connection for online gaming, do port forwarding. Maybe because the ports are blocked thats why you are getting poor connection. NAT is just designed to translate public IP to private for you to communicate world wide.
    Jun 19, 2011 | Zhone ADSL2+ 1PORT BRID/RTR ANNEX...
    Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
    It sounds like you need to "crossover" the connection.
    Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (
    However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
    I hope this helps.
    Jan 27, 2010 | Adtran NetVanta 3305 Router
    Can not ping our netvanta 3200 from behind a Linksys nat router
    The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
    Dec 29, 2009 | Adtran NetVanta 3200 Router
    Password apparently lost on Netvana 3200 - any hidden reset?
    connect console cable
    Bootstrap# bypass passwords
    Bootstrap# boot
    Oct 20, 2009 | Adtran NetVanta 3200 Router
    Adtran Telnet
    Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
    Jun 23, 2009 | Adtran Total Access 850 Router...
    Adtran Atlas 550 alternatives
    1: Would a Cisco 1720 provide a simple soltution for terminating a T1 to Ethernet 100 Mps I recommend a 1721 2: If this would not be an option, what Cisco box would provide the needed termination/routing I recommend a 1721 3: If a Cisco device could do this would it be necessary to replace them at both locations or could it communicate with the Adtran device. It depends on the topology of how your sites are interconnected to each other. Please describe in greater detail.
    Apr 30, 2007 | Adtran Atlas 550 Router
    Adtran ESU LT Modem Logo
    103 people viewed this question
    Top Adtran Computers & Internet Experts
    Gareth Tomlinson
    Gareth Tomlinson
    Jax Planet
    Jax Planet
    Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
