Question about RCA F27252GY 27" TV
RCA 20 When I hit the power button it doesn't turn on but you can hear a continuous clicking noise and also a spark in the back like it's trying to turn on but nothing happens. Anyone know what this could be. Thanks.
  • 661 Answers
Sounds like the Power Transformer to me,  usually accompanied by a high pitch (almost inaudiable whine) and  sparks arcing.
This needs a professional repair..
Posted on Oct 11, 2007
SOURCE:
My 2000 Pontiac Montana won't start. I hear a clicking noise from the back but the starter doesn't engage
have somebody hit the starter with a hammer while somebody turns the key on the start position as he holds the key keep hitting the starter not at the solenoid at the round part if it tries to start then you have a defective starter now if you have a alarm system you are going to have tutoo isolate the starter to do a different test.
Apr 16, 2013 | Cars & Trucks
I lose all power in my 2004 roadstar 1700 when i push the starter button
Sounds like cables are not making a good contact. Take the cables off the battery and clean them and the posts. If that doesn't fix it check the cables at the other ends at the starter and ground. Make sure you take them off and clean them good cause they can be tight and still not make a connection.
May 25, 2012 | 2004 Yamaha Road Star Silverado
When i press the power button, it doesn't really come on, it makes a clicking noise then it shuts off. What could the problem be and how can it be fixed?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, (If desktop Open the Case) ( If Laptop Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop)) and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 21, 2012 | LG EBR68351604 EBT61082804 EAX613586031...
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
When i turn on, the green light comes on then goes out,why
Mar 28, 2012 | Computers & Internet
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Continuous click noise like its trying to turn on but will not.
I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode.
Feb 23, 2009 | RCA F38310 38" TV
RCA F27252GY 27" TV Logo
99 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
