Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Rear wheel drive on mower does not engage
How to repair drive on rear wheel drive craftsman mower w honda engine. wheels do not engage
  • Richard Scordino May 11, 2010
    Try spraying wd 40 all over the brake control mechanism on the right rear axle, then work the controls a few times. A lot of them freeze up after storage.
  • 86 Answers
Its possible that the cable slipped does the pulley turn on top of trans.if so does the shaft turn if so then your gears on wheels need cleaned or replaced.
Posted on May 11, 2009
My YTH2648TDRF has only one rear wheel that engages the mower, shouldn't both rear wheels drive?
The rear drive uses a differential to drive the rear wheels, just like a car, the differential drives the wheel with least resistance, to enable the wheels to revolve at different speeds when going round corners; so it's quite normal for only one wheel to be driven. If your mower is having difficulty with slopes (do you call them grades?) I suggest you fit a new drive belt, a slipping belt is the most common cause of low power. Hope this helps.
Jan 12, 2016 | Husqvarna Garden
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Honda hrr2163tda rear drive problems
remove the rear whheels and check the drive lugs on the axles to see if broken or just rusted or stuck down
Feb 21, 2013 | Garden
Only one rear wheel on my gxv 160 self propel is engaging and cannot remove the wheel as l have new replacement ones to put on
its most likely going to be the drive tangs behind wheels put a set of vice grips on the axle then you should be able to to undo the bolt in the middle of the wheel or use a air rattle gun
Feb 16, 2013 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
I have a Craftsman, front wheel drive mower. I have replaced the front (drive) wheels every 6 months for the last two years. The plastic gears on the wheels just get chewed up. What is the problem?
Must be a bad mower that got thru the assembly line somehow. I have owned a front wheel drive Craftsman mower for 7 yrs and have never had one single problem with anything on it.
Aug 24, 2012 | Craftsman Front Propelled Rear Bag Lawn...
Lawnmower wheels jamming/sticking rear wheel drive
Unless you want to replace these gears You can make this mower into a push mower by taking the wheels off and disconnecting the gear drives. One time I took wheels off the front and put on the rear and rear off the back and put on front. In order for this to work all four wheels have to be the same size.
Dec 23, 2017 | Garden
Craftsman mower #247.887760 rear drive. rear wheels lock-up when you try to pull mower backwards
The rear wheels are locked to the drive train. To pull or push the mower, you must pull out the release probably at the back of the mower, near the transmission.
Gary
Jul 10, 2011 | Craftsman Garden
Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Jun 02, 2010 | Garden
Rear wheel drive does not push mower when engaged. But, when mower rear wheels are lifted off the ground, they turn weakly.
remove the rear wheels and check the gears in the wheels- they are plastic and part of the circumfrance on the inside of the wheel. If worn replace wheels.
also check belt- it should be tight with very little play when drive is engaged ( obvioulsy check this with engine off).
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Rear wheels will not turn. Worked fine when stored for the winter
Craftsman-Husky...same tractors-built in the same factory. I also had a problem with the hydrostatic transmission not providing power to the rear wheels. Here's what Sears told me:
(1) Check to make sure the drive belt is tight both under the engine-and the tranny.
(2) Air can get into the hydrostatic transmissions-especially during shipping (new mower) and storage.
So.....
Pull your freewheel pin out to disengage the tranny-then push the mower both forward and then backwards for 50' or so. Then push the freewheel pin back in and start the mower. If the transmission then works-drive forward-then backward-then forward repeating the cycle about 4 times. Drive about 50' in each direction. This should purge the air from the treansmission.
Mar 20, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
338 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
