Question about Kenmore 53642 / 53644 Side by Side Refrigerator
No ice to the door
When pushing glass against lever for icemaker, the corkscrew does not turn inside but sound like something is trying to work can the parts inside the door freeze it sound like a motor is lock up in the door. it clicks when you push a glass against the lever
  • 21 Answers
The motor is behind the ice bin and yes, it can get water on it and freeze up. I actually fixed one a month ago that I had to remove the motor and let it dry at room temp for a week in order to get it to work when reinstalled. Two or three days and it would freeze right back up in a little while. This usually happens when you've had a problem with the waterfall into the ice reservoir that a bit pours over the edge or when you've defrosted the freezer or left it open long enough to let ice thaw to some degree. You can pull the ice bin out and twist the motor by hand. If it is stuck it is froze but if it moves it is probably bad. You can close the switch with the door open and check with a volt-meter to see if there is voltage going to it if the motor turns freely. It will have a lot of tension but you can turn by hand.
Posted on May 09, 2009
I have the same issue, I can get water but my ice maker cork screw does not turn, it makes ice but does not dispense it. What can I do to fix it
Posted on May 24, 2009
MY CAN GET WATER OUT OF THE WATER BUT FREEZER WILL NOT MAKE ICE ?
Posted on May 25, 2009
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
I have a jsd2789ges jenn air water dispenser not working at all
hi there,
sounds like you have an icemaker problem. i would recommend replacing it.
Oct 02, 2008 | Jenn-Air JSD2789GES Side by Side...
Kitchen Aid indoor ice maker
hi there,
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Jun 14, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Ice Maker Trap door may be broken
I am having the same problem. My husband took off the front panel and we discovered there is a small piece of plastic holding the ice dispenser door in place that is broken so the door doesn't seal.
I called Sears to see if the part is replaceable -- it's not. I have to buy an entire freezer door for $464 because a .10 cent piece of plastic is broken.
This seems to be a common problem. My refrigerator is only 3 years old. Perhaps we need to make a complaint to Sears/Kenmore together.
May 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker does not make ice and the in-door water is not working properly - it keeps running.
the water in the door problem after you fill up your cup with water it keeps running all over the floor.. it sounds like its a stuck contact on a micro switch inside the door compartment. that lever you are pushing your glass onto is atached to a little switch and if the contacts stay closed (like when a glass is pushing on it) the machine thinks "hey he still wants water". next time it does that try pushing on the spot you put the glass onto a couple of time to see if it stops the water. if so it most likely is the switch. to confirm that is the case you will have to open the plastic moulding from the fridge door to gain access to the switch.( always unplug any electricall device before openning to ensure your hair doesnt end up standing striaght up like a punk rocker) you will know which switch is the one you want to check by depressing the water lever on the front. Ohm check the switch for continuity to see if it gives you proper readings or it is in fact a bunk switch. it also could be a mechanical problem as the lever once unpressed is not opening the switch back up once the glass is removed but that is not as likely unless you are ramming the glass into the water dispensor
hope it helps
VeeDubb
Apr 23, 2008 | Refrigerators
Ice maker constantly runs
You do not have the actuator postioned correctly on the switch inside the door. The lever has to press up against the switch when you push it. Re-postion the lever.
Apr 11, 2008 | Frigidaire PLRS267ZAB Side by Side...
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Sep 12, 2007 | KitchenAid Architect ® Series II KSRX25FT
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
173 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
