Have a lens error like others. Are there any solutions other than sending to Canon or a repair facility to repair it. Camera was not dropped. Tried to turn off and on. Won't focus and when the lens is extended fully, it shuts off stating lens error. Any suggestions to repair this?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
If your lens is jammed, then there are a few things that you could do, but I can't endorse those methods as they can cause even worse damage to your camera. However, if you look to get it repaired, you can get it repaired for fairly cheap (certainly less than what Best Buy or Canon will tell you) Just do a Google search for Canon SD870 lens repair, there are a few options for you!
how do we show video that has been recorded already
cannon powershot sd870 is.
which buttons do...
(More)
which buttons do we push to see the video?
when I take a shot close up the image is blurred. It seems to take a few seconds for the shot to be...
(More)
when I take a shot close up the image is blurred. It seems to take a few seconds for the shot to be taken after I have pressed the shutter button??
I have a Canon SD870. I am getting replace battery with a fully charged battery. I have tried 2...
(More)
I have a Canon SD870. I am getting replace battery with a fully charged battery. I have tried 2 batteries. What could be the problem?
My camera will no longer take a picture when a flash is needed. We can take pictures without flash,...
(More)
My camera will no longer take a picture when a flash is needed. We can take pictures without flash, but they may be blurry or dark. It almost seems as though the flash might be broken or it's a dead bulb.
Canon 870 when taking pictures outside they look fine in the lcd screen prior to shot then after...
(More)
Canon 870 when taking pictures outside they look fine in the lcd screen prior to shot then after shot taken a bright light appears almost whiting out the whole picture
