Question about Kenmore HE2 Plus Front Load Washer
Noise making sound like a motor cycle would not move
  • 460 Answers
Lets begin
1.-Unplug washer or disconnect power.
2.-Check drive motor.
3.-Check drive belt.
4.-Check wire harness connections.
5.-Plug in washer or reconnect power.
6.-Check the MCU by looking for operations of the drive motor
in both directions.
was this helpful?
Posted on May 12, 2009
Loud continuous buzzing noise while dishwasher is running
Hi hope you are well have you checked that the dishwasher isnt touching your units either side their should be a slight gap either side you will get this noise if it is touching anything at the sides or pressed up against something at the back if this is not the problem.
If it is making the noise through most of the wash cycle the the chances are it isnt going to be a pump on the way out the only other thing it could be is the motor that turns the spray arms around and it could be either the top or bottom usually if you can get to the motors you can oil the moving parts as sometimes thse get dry over time.
Try the first sollution first try moving the dishwasher a bit and then try it again if still noisy then the chances are one of the motors has got noisy on the spray arms it wouldnt be the pumps as the noise continues through most of the wash.
Some times just moving the dishwasher will recitfy the problem as the same happens with fridges and freezers if it has been knocked and is not level or is touching a unit you will get a slight vibrating noise so try moving it a bit.
Let us know how you get on
Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine knocks in cycle
if its a whirlpool top loading washer, sounds like a bad motor coupling.( the machines equivilent to a belt.)
Oct 25, 2008 | Washing Machines
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Kenmore HE2 Plus Front Load Washer Logo
57 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
