Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Vacume is a mach 4 cyclonic, it runs for about 8 minutes and then it shuts itself off? any idea?
  • 2 more comments
  • gojofoenator May 09, 2009
    Yea, don't know what is up? I thought it was overheating because the dust cup was filling up and the cyclonic holes were plugged, i took some time and cleaned it spotless, cleaned out the holes, after using it again it started up doing the same thing. Seven eight minutes its shuts itself off, no really bad smell either..About a year old, been doing this for a while. What's up.. seems like everyone I know is having vacum problems...
    yea the Hoover cyclonic mach 4 run ok otherwise, just runs for about eight minute and then it shuts itself off. Anyone have anyideas?
  • gojofoenator May 14, 2009
    no hepa filter that i can see, will try to keep cleaning it, hoover
    tempo that sells for $69 is the best rated vacuum, if i have to buy a vacuum that is what i am buying..thanks for the input
  • wavoconqueso
    wavoconqueso May 11, 2010
    It's probably protecting itself from destruction from overheating. How's the suction, hot, smells hot? How old is it? Does it run normally otherwise?
  • 57 Answers
The only thing I can think of from your additional comments is when it warms up something expands and it loses continuity of the circuit. Most likely the switch or the breaker.
Another thing to check is if it has a hepa filter it may be clogged and is tripping the circuit. Try this. Remove the hepa filter, turn it on and let it run without vacuuming anything. If it continues to run past 10-12 minutes get a new filter.
Posted on May 10, 2009
  • wavoconqueso
    wavoconqueso May 14, 2009
    Ok. Sorry I couldn't be more help.
It is a Hoover mach 5 runs a few minutes then shuts off no power laglass@sbcglobal.net
This sounds like a thermal limiter issue, usually caused by restricted air flow. Investigate until you find a blockage.
Dec 12, 2010 | Hoover U8145-900 Savvy Bagless Upright...
The machine runs for brief periods, then shuts itself off. If it is allowed to sit for several minutes, it runs again, then shuts itself off.
the motor is heating up to much and the cut out switch is kicking in. You need to check the the motor filter, and worse case you may need to new motor..
Oct 04, 2010 | Dyson DC14 All floors Bagless Upright...
I turn my dyson on and it runs for 5 min then turns off
The motor may not be getting air flow past it due to clogging or dust build-up. It is probably shutting off because of a thermal overload switch. Good luck!
Jan 07, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
We have a dyson root cyclone and it shuts off after a about 5 minutes of running. Then after about 10 minutes it will run again.
Your description is typical of a machine that's overheating. This is almost always caused by a blockage, as restricted airflow can't keep the motor cool and the automatic cut-out shuts the machine off. It re-sets itself when it's cooled a bit. Check your operator manual for how to clear blockages, and also check that your filters are clean.
Nov 28, 2009 | Vacuums
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Hoover Mach 4 Overheats and shuts down after a few minutes
You have lost air flow due to blockage. Look for blockage in the throat of the machine where dirt enters from the floor. Do this by removing the base plate or opening throat inspection flap if so equipped. Also detach the hose and drop a coin through to see if there is and obstruction in that area.
Sep 07, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Vacuums shuts off during use
 My guess is: Either a loose contact on the plug  or Intermittent electricial open  in the electric cord itself. To confirm. Try wiggling the cord and ends while running. If you find the place yo ucan either replace the cord or repair it.
Dec 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacum just shut off when vacuuming
Could be clogged. Check hose check sole plate if its an upright, check handle of hose if its a canister type or check the filter inside the bag/bin area i.e the white or black filter either behind the paper bag or cyclone- if its clogged with dirt then the vacuum may have functioned its thermal cut out - which can take up to 45 minutes until the motor cools down and resets itself.
Jul 04, 2008 | Dirt Devil Vacuums
I HAVE A BRAND NEW HOOVER MACH-3 CYCLONIC THAT CUTS OFF EVERY FEW MINUTES. IT IS DRIVING ME CRAZY! IT'S LIKE AFTER 5 MINUTES OF VACUUMING IT HAS TO SIT FOR A LEAST AN HOUR THEN YOU CAN VACUUM FOR ANOTHER...
If it were mine and it was brand new I would bring it back and exchange it. It sounds like the motor is over heating and shutting off automatically. Does not sound good. My advice return it.
Mar 16, 2008 | Vacuums
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
198 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
