Question about DFI NFII ULTRA-AL Motherboard
Wont power up!
I have a acer laptop {aspire 3000 series}was useing it last night,was going great,closed it down and left it pluged into the wall,went to switchit on but the power light comes on for 1-2 seconds then turns off,need help!
  • ronfx4 Nov 02, 2007
    i have a compaq presario 1200xl500 i left it plugged in. i went back to use it and when i go to turn it on the power light comes on and then goes off. it shows the battery light and a/c cord lights are on but it wont power up. please help!!!!!!!!!!!!
  • Anonymous Dec 29, 2007
    i push the power switch and it wont turn on
  • 40 Answers
May be the battery is dead (i.e. uncharged). Connect to an electric network and try once.
Posted on Oct 12, 2007
SOURCE:
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer aspire 3610 graphic or battery problem?
It sounds like your backlight is damaged. On some units this can be replaced on its own. On others, it requires the entire LCD to be replaced. I'll see if I can find out which this is, in your case, and find you a part number.
Sep 01, 2007 | Acer Aspire 3610 Notebook
Good Afternoon, I have the Acer Aspire 10''
From the symptoms, the computer Operating system seems to be corrupted.Try to follow the steps
Try booting to BIOS by punching DELETE / F2 key on startup.Then press F9 key, load the defaults.After that press the F10 key to save them and then start tapping the F8 key to get the repair my computer options.Select safemode .If the computer is booting to safemode, you can try doing a system restore.If the unit is not booting to safemode, then the Operating system has to be reloaded.
Oct 24, 2010 | Acer Aspire One PC Notebook
Acer aspire one won't turn on
Try another Wall Power Supply. To test. Take Out battery, Plug In wall supply to Wall & PC, without battery does it work OK? IF YES, replace battery still OK? Laptop Should work on Wall ONLY, if not, replace wall unit.
Apr 28, 2010 | Acer Aspire One PC Notebook
My acer aspire 3680 wont power on. i pluged it in and the wall outlet kind of sparked and now my computer wont come on at all
Hi did you try plug in other wall outlet to see if its the charger that is bad? and you can try using another charger 1 you sure is working this will determine if it is the charger or computer is damage.
thank you
if my advice is helpful kindly vote for me
hbristol173
Mar 31, 2010 | Acer Aspire 3680 Laptop
I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
Nov 05, 2009 | Acer Aspire 7720 Notebook PC
I'm having problems with my acer aspire 3000.
The battery is just discharged fully. Plug it for few hours idle before your next try.
This should fix it.
Cheers
Don't forget to rate this
Mar 22, 2009 | Acer Aspire 3000 Notebook
Acer aspire one will not work.
If you get a post screen with Acer written on it at startup, and the screen turns off when loading the system (Windows or Linux), then you need to reinstall the system using an external USB cd unit and the recovery disk that was provided with your Acer.
If instead the display has no screen at all , try connecting an external monitor to test the laptop.
If you get picture on external monitor, then the Aspire One has a faulty LCD ribbon cable or a faulty LCD display or inverter.
If you get no picture on external screen , then you have a faulty motherboard, possibly faulty video chipset on motherboard.
In any case check your Acer One warranty, all the faults listed are covered by Acer warranty for one year.
Contact Acer at the number listed on documentation to have the computer repaired.
Mar 13, 2009 | Acer Aspire One PC Notebook
Cannot start up my laptop since in done an update
Try booting into "Last known good configuration" it is on the same screen as Safe Mode, if that does not work, you can try to run CHKDSK /r from the windows install CD, just choose "Repair" in the option, if this does not work I suggest removing that hard drive and slaving it into another computer to get your data off and then reload Windows onto it. It is missing a .dll
Nov 28, 2008 | Acer Aspire 1642WLMi Notebook
Open Questions:
MCAFEE TeCH sUPPort pHoNe ~\18OO/8\O/3\1O69/~ numbeR activations Usa MCAFEE USA phone number is ranked #2 out of 2 because 7,728 MCAFEE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he MCAFEE USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, MCAFEE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MCAFEE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact MCAFEE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling MCAFEE USA Calling MCAFEE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MCAFEE USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MCAFEE USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MCAFEE USA's phone numbers against each other. Contacting MCAFEE USA in General While I8OO8O31O69 is MCAFEE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach MCAFEE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MCAFEE USA.
Oct 18, 2019 | Mcafee Computers & Internet
See all DFI NFII ULTRA-AL Motherboard Questions
DFI NFII ULTRA-AL Motherboard Logo
89 people viewed this question
Top DFI Computers & Internet Experts
Ekse
Thomas F. Schneider
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
