Question about Nintendo DS Lite Console
Replaced the shell and now the touch screen isn't responding!
The hinge broke on my sons ds lite, so I replaced the whole shell, but when I'd finished the touch screen comes on but is not responding, also when I plug it into recharge, that is not working either, the red light doesn't come on!! Please can somebody help me, my son is going to drive me nuts if he can't play with his ds lite!!!
  • julie51 May 10, 2009
    Thanks for the advice, I have tried it all again, but still not working, I think the screen cable may have got damaged, I think I will have to buy a new touch screen, will this solve the problem?
    Scholar:
  • 32 Answers
I have actually done this same thing attempting to repair my old gray DS. Had to replace the screen to screen cable and touch pad, but that is another matter.
When the DS screen to screen cables are out of place, the DS will act exactly like this. The screens will flash once and the DS won't even attempt a charge. This is a safety feature of sorts in the DS design to prevent a possible short.
I'm assuming you had to remove the screen to screen communication cable when replacing the shells so you most likely didn't put the cable in all the way into the correct ports.
Sometimes even if they are off just a bit the machien just won't use it and act like its outright dead.
Best thing to do is to go back and reinsert the cables again.
There should be a small line on the board just under where the cable should be. You need to try and aling the cable with this line as best as you can.
Push the cable as far back into the port as you can without forcing it in. You should never need to use much force at all.
Press the plastic tab down and lock the cable in place with the port and do the same with the second one.
Once thats done, plug it in and turn it on.
It should normally go into the settings as these are usually erased when the battery is removed.
If it continues the odd dead like behavior. Simply attempt the precedure over again until you ahve it right.
Commonly you may see odd colorisation and the like if the cable is in enough but not in just right.
Take your time with it and be paient. Its not always easy but isn't too hard once you figure it out on your own.
The same info should help with other cable problems like this aswell.
Good luck with the rerpairs.
Posted on May 09, 2009
  • shadow1w2
    shadow1w2 May 10, 2009
    replacing the screen to screen cable would most likely work. Replacing the entire screen is costly and not always worth it.
    There are shops that sell the screen to screen cable, or "screen communication module" as I've heard it called, for rather cheap. They aren't official parts but they do work.
    I suggest looking for one of those before replacing an entire screen.
    Most cases are that the cables are not in completely.
    It takes a lot of adjusting but keep with it.
    Never hurts to buy a spare part, but usually with the DS machines they will be rather picky about being in the right spot.
I am replacing the shell on my ds lite and when after puting it back together the touch screen lights and works the the touch pad doesnt respond
It sounds like when you replaced the shell, you may have not reconnected the touch screen's membrane sensor. I'd open the system back up and make sure there aren't any loose or disconnected wires.
Mar 15, 2011 | Nintendo DS Lite Console
Power led lights green, touch screen flashes white and powers off
try taking it apart again and checking closely to see if any inner cable is loose,
Apr 13, 2010 | Nintendo DS Lite Console
Ds lite
sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Jan 29, 2009 | Nintendo DS Lite Console
Touch screen wont respond
double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Thanks
Josh Boyer
ninja_freak318@hotmail.com
Jan 22, 2009 | Nintendo DS Lite Console
Nintendo DS hinge broke
You can find the info for replacing the shell here:
http://site.powergamingparts.com/RepairNdsl.html
Dec 22, 2008 | Nintendo DS Console
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Nintendo ds broken hinge
need to replace the hinge (shell housing) about $25.00
Aug 22, 2008 | Nintendo DS Lite Console
Dropped and broke !
If your pretty good at dealing with small wires and parts there is a guide I found dealing with this problem
http://www.instructables.com/id/S405TMEFA0CVIFR/
Hope this helps and good luck repairing your son's DS Lite.
Jan 14, 2008 | Nintendo DS Lite Console
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
Jan 07, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
220 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
