Question about Akasa Fan Speed Control Fan Controllers
Antec fans connected to akasa fan controller, Speed doesn't change
I connect my Antec Tricool fans to the fan controler and the controller detects the speed but when I turn the knob, the fan doesn't change speed. Is this a problem with all Antec fans? Do only Akasa fans work with the Akasa fan controller?
    Problem Solver:
  • 5 Answers
U need the correct connections
Posted on Dec 18, 2009
    Scholar:
  • 109 Answers
Sounds like a problem with your fan controller. The controller is simply controlling the voltage applied to the fan to adjust the speed. Have you tried a fan without a speed control built in?
Posted on Jun 23, 2009
I have 2000 impala.. Code 0481 I've replaced the relay even though both fans turn on fine. I also swapped the plugs to see if I would get a fan 1 code and still got 0481. Any ideas?
DTC P0481Cooling Fan Relay 2 Control Circuit .
You swaped what plugs ? Fan's ? That wouldn't change anything ! You need to know how these duel fan set up's work . With this code the fans will still work in low speed , not high !
Output driver modules (ODMs) are used by the PCM to turn on many of the current-driven devices that are needed to control various engine and transaxle functions. Each ODM is capable of controlling up to 7 separate outputs by applying ground to the device which the PCM is commanding ON. Unlike the quad driver modules (QDMs) used in prior model years, ODMs have the capability of diagnosing each output circuit individually. If an improper voltage level has been detected on ODM B output 2, which controls the high speed, relay 2, and series/parallel cooling fan relays, DTC P0481 will set.
Do you know how to do automotive electrical testing ?
Diagnostic Aids
Check for the following conditions:
• Poor connection at PCM -- Inspect harness connectors for the following items:
- Backed out terminals
- Improper mating
- Broken locks
- Improperly formed or damaged terminals
- Poor terminal to wire connections
• Damaged harness -- Inspect the wiring harness for damage.
• If the harness appears to be OK, disconnect the PCM, turn ON the ignition and observe a digital multimeter connected between the Fan Relay 2 driver circuit and ground at the PCM harness connector while moving connectors and wiring harnesses related to the series/parallel fan relay and the high speed fan relay. A change in voltage will indicate the location of the fault.
If the DTC cannot be duplicated and is determined to be intermittent, reviewing the Failure Records can be useful in determining when the DTC was last set. Also refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
Relay Driven Dual Cooling Fan Diagnostics
Apr 24, 2017 | Cars & Trucks
Haam air conditioning split then I switch on come to E7 what is the problem in my a c please give me answer any parson
Malfunction of Outdoor Unit Fan Motor ( E7)
Remote Controller
Display
E7 Method of
Malfunction
Detection
Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
fan motor runs.
Malfunction
Decision
Conditions
?? When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
running conditions are met
?? When connector detecting fan speed is disconnected
?? When malfunction is generated 4 times, the system shuts down.
Supposed Causes ?? Malfunction of fan motor
?? The harness connector between fan motor and PC board is left in disconnected, or faulty connector
?? Fan does not run due to foreign matters tangled
?? Clearing condition: Operate for 5 minutes (normal)
Troubleshooting
Caution
Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
occurred.
Replace the outdoor unit fan motor.
Connect the connector.
Remove the foreign matter.
YES
NO
Are fan motor
connectors
disconnected?
NO
YES
Is the pulse input?
Check No. 11 Check for pulse input
for number of rotations
on the outdoor unit
PC board.
Replace the outdoor unit PC board.
YES
NO
NO
YES
Is there
any foreign matter
around the fan?
Can the fan be
easily rotated by hand?
(S2584
Jun 07, 2016 | Heating & Cooling
Computer fan is spinning slowly
buy another fun and replace the old one
May 01, 2013 | Antec TriCool 80mm Blue LED Fan Case...
Troubleshooting 2002 Tahoe blower control processor (resistor)
The orange wire is fuse protected, hot all time. Did you mean .30 volts? Unless I missed something, I don't understand 30 volts? What ever your reading is across battery posts, the reading at the orange wire should be close to the same. Battery has a full charge and connections all good? The wire at the bottom is chassis ground. The wire at the top goes to havc control module, it is for blower speed control. That may be a pwm/pulse width modulated signal?
Any hvac trouble codes?
Aug 15, 2017 | Pontiac Grand Prix Cars & Trucks
Where do i plug my 4hole plug to my desktop on tricool 92mm
You should be able to figure it out with these pictures:
6_1_2012_12_00_30_am.jpg6_1_2012_12_00_56_am.jpg6_1_2012_12_01_19_am.jpg6_1_2012_12_01_36_am.jpg6_1_2012_12_01_57_am.jpg6_1_2012_12_02_15_am.jpg6_1_2012_12_02_43_am.jpg6_1_2012_12_02_59_am.jpg
Good Luck!
May 30, 2012 | Antec TRICOOL 92MM DBB MPN:TRICOOL 92MM...
Remote control will not turn on fan
Do you have the correct type of fan connected to the motherboard ?
For fan control to work you must be using the type of fan that has at least three wires in the connector plug (if it has four wires that is ok too) but if it only has two wires then it will not works since the third wire is the control wire that the motherboard uses to detect fan speed and so on...
Fans that connect through a connector on the power supply will not work either must be conected to motherboard plug on the motherboard itself with at least three wires
hope this info helps
NOTE: if you are sure you are using the correct type of fan then check BIOS power/hardware monitor settings to see if the fan is connected to the correct plug on the motherboard and to verify it is being detected properly and fan speed setting is correct.
May 15, 2011 | Computers & Internet
Cooling fan for antec power supply pp 303xp does not come on when computer is switched on. Is this a replaceable item or do I have to buy a new power supply?
I THINK I REMEMBER reading that Antec had introduced a feature on some of their psu s where essentially the fan(s) were thermally controlled - if the psu was not working very hard it remained cool and the fan remained off but as the psu got warm with additional load it gradually increased fan speed. Perhaps this the issue you are seeing and nothing is wrong ?
PSU's are generally difficult to open and contain few accessible parts. some you can actually change the fan. I don't know about yours though.
Jan 04, 2011 | Antec PP-303XP 300WATTS ATX12V ATX POWER...
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
I cant control fan speeds
Download a free fan utility called Speedfan, you may be able to get it at www.download.com
Sep 14, 2009 | Computers & Internet
Canon W7200 Error code E02D05
The Service Manual says:
E02D05 Airflow fan error
Fan rotation could not be detected while the air flowfan as running.
Probable problem locations
Air flow fan, engine controller, system controller
Remedy
1. Cable connection check (check - replace
2. Replace air flow fan
3. Replace engine controller
4. Replace system controller
I wish success
AToe
May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Akasa Fan Speed Control Fan Controllers Logo
398 people viewed this question
Top Akasa Computers & Internet Experts
David Payne
David Payne
Are you an Akasa Computer and Internet Expert? Answer questions, earn points and help others
