Question about Plumbing
Problem removing old flapper unit from Mansfield tank
I just purchased a Fluidmaster W43AK complete toilet repair kit. I have a mansfield tank and connot remove the old flapper unit. One piece just slipts over a housing and connect to the flush handel. The other piece appears to be part of the bowel and cannot be removed. help
  • 121 Answers
Disconnect the water supply first. Then use a large channel lock and remove the large plastic nut on the botton side of the supply system. Take the old one out and replace it just use caution when retightening the nut. The porcelon is very delicate. Check for leaks after you have turned the water back on and if you have to carefully tighten it some more. I hope this was helpful Have a good week end! : )
Posted on May 09, 2009
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Replacing fill valves in mansfield 160 toilet
If this is the standard manfield 160 toilet I recommend replacing the fill valve with a Fluidmaster 400a. They are easy to install and adjust , and work very well.I have installed hundreds of these and have had zero problems. Hope this helps.
Sep 11, 2010 | Mansfield Plumbing Products Mansfield...
My Mansfield toilet model 160 runs periodically for no reason. What is the problem? Do you have step-by-step instructions how to fix it?
The flapper is bad....and allowing water to go through into the bowl very slowly...You need to find the correct flapper for that toilet....even all Mansfield toilets can have different guts inside....then replace the flapper which is very easy to do...
heatman101
Sep 10, 2010 | Home
MANSFIELD TOILET KEEP LEAKING
I'm not exactly sure where the seals are that you are describing. I'm thinking that you might need to shut the water off, unbolt the toilet from the floor, and replace the big wax toilet gasket underneath.
That's the main seal for internal plumbing in the toilet, unless you're talking about the toilet leaking into itself and wasting water. In that case you might need to simply adjust the mechanism (float, flapper valve etc.) to get the right setup.
I'm not sure I completely understand your problem though.
I hope this has helped anyway.
Lyle
May 03, 2010 | Mansfield Plumbing Products MANSFIELD 3/8"...
I cannot get the bolts to seat correctly and the tank leaks
You have a Broken Flange.
Not a hard fix, There is a repair kit.
Don't get the Half Flange repair kit... Get the Complete hole metal flange repair kit, install and also replace the wax ring and your back in business.
Hope this tip helps.
r/
David
Jan 20, 2010 | Mansfield Plumbing Products Mansfield...
Runs all the time
TO AVOID ALL PROBLEMS INSTALL A NEW FILL VALVE FLAPPER. THERE ARE MANY UNIVERSAL KITS YOU CAN USE . TRY FLUIDMASTER
Jan 06, 2010 | Mansfield Plumbing Products Mansfield...
The flush valve gasket is leaking so the toilet water runs periodically
You prbably just need a new flapper valve. Buy one at Home Depot for a few bucks and it will, simply, snap into place at the base of the tank. Also, make sure that the chain is not too tight and cut off any excess chain after the flapper is installed.
Oct 26, 2009 | Mansfield Plumbing Products Mansfield...
My Mansfield toilet has a broken float rod and it seems like a need a Mansfield made replacement kit, is that true? I can't use a standard store bought replacement kit on Mansfield toilets?
mansfeild toilets are very common Korky or Fluidmaster makes a replacement ballcock and will change out easy I wouldnt fool around trying to find parts and replace the valve they run about 15 -$20.00 and replace the flapper at the same time
Aug 23, 2009 | Home
Plumbing Logo
264 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
