Question about Bionaire BDQ25 Dehumidifier
Where to buy drain hose
Need drain hose
  • 148 Answers
Any plumber supply company will have the hose you need just need to know what size
Posted on May 10, 2009
Danby ddr5511r owner manual
Yess the DDR5511R has the drain hose connection inside the compartment where the water bucket sits. It is at the top right corner. You have to remove the water drawer to see it. At the right side of the unit (on the outside) is a small "door" that flips up so that you can feed a hose throught to the threaded outet inside. The drain hose is not supplied with this unit.
Mar 26, 2012 | Danby Dehumidifiers
How do I install a hose so this humidifier drains automatically?
Look at the drain pan, it might have a garden hose connection that you might have to knock out, mine is not the same model but it may be similiar, and then run it to a floor drain or such. Good Luck
Jun 30, 2011 | Whirlpool AD50USS Dehumidifier
Is it possible to buy a tube that will allow me to drain my dehumidifier (Whirlpool Accudry AD25BBL6) into my ejector pump that I use with my air conditioning unit?
A standard Garden Hose will work. However, the hose can not be any longer than 5 feet and must always slope downward. As, there is no pump in the dehumidifier. It relies entirely on gravity to drain thru a hose. So, unless your condensation pump is within 5 feet of the dehumidifier, it won't work.
Hope this helped you. Please let e know.
Jun 28, 2011 | Whirlpool AD25BBK Dehumidifier
Where do i find the model number for an older model goldstar dehumidifier and where can i buy a hose to connect it directly to the sump pump?
Any garden hose will fit the drain connection on your dehumidifier. However, the hose can not be longer than 5 feet. As the drainage relies entirely on gravity to drain. Connecting it directly to a sump pump is not a good solution. Allowing the hose to drain into the sump pump's water collection tank is your only option.
Jun 24, 2011 | Goldstar Dehumidifiers
I am thinking of buying the ADER50LP. Can a drain it directly to a floor drain, by-passing the bucket? If so, does it have an external spigot or will I need a hose? Are ADEW50LP and ADER50 LP identical?
You will need to use a drain hose that is no longer than 5 feet. Using a hose relies entirely on gravity. So, the hose must slope downward with no kinks. A short 5' section of Garden Hose works well. The female coupling end attaches to the dehumidifier. It's a very effective way, not to having to stop and drain the tank time it's full.
The ADEW50LP, is a low Temperature Unit, which designed for basement applications.
The ADER50LP, is a standard unit. Used for all applications, other than a basement.
Both have the external drain feature and the same water extraction capacity.
Hope this helped you. Please let me know.
Jun 21, 2011 | GE Ader50ln Dehumidifier
Need manual for fedder dehumidifer to hook up drain hose. need to know were drain hose connects.
Pull out the water collection tray. You will see a small pipe (about 1/2" diameter) in the top of the area where the tray came from. This is the "drain" that fills the tray. Connect a hose to this pipe and run the hose to a floor drain if you have one. I used a section from an old garden hose for my unit. There also may be a small opening in the back wall of the dehumidifier to route the hose more aesthetically.
Dennis
Jun 12, 2009 | Fedders A7DH45B2A Dehumidifier
LG LHD45EL Dehumidifier
Push through the membrane with the drain connector. The membrane has a circular cut almost all the way through it, and pushing at it with the drain connector will pop out the little hole. I've done it with four LG units.
Sep 06, 2007 | LG DH30 GoldStar Dehumidifier
Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Jul 05, 2007 | Maytag M3DH30B2A Dehumidifier
Dehumidifier Kenmore 580.54501
hose connector is Sears part # 5214A20027A
dehumidifer is Model # 58054501300 or 58054501400
use these numbers on searspartsdirect.com
Jun 11, 2007 | Kenmore 54501 Dehumidifier
Drain problem
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
Apr 03, 2007 | Maytag M7DH65B2A Dehumidifier
Bionaire BDQ25 Dehumidifier Logo
120 people viewed this question
Top Bionaire Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
