Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front loader washer, the handle broke off!
I ordered the part from Sears (brought it there) but I want to open the door and use it until the part gets here next Tues. Any suggestions?
  • 51 Answers
USE A BUTTER KNIVFE IN AN SLIGHTLY PRY DOOR OPEN
Posted on May 16, 2009
My whirlpool front loader door won't open f3e2code
the door lock may need to be changed as door safety is not unlocking so door not opening
Dec 22, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washer has a cracked front plasitic clear door that I need replaced. Where can I order this? The handle just cracked at bottom of screw. That also needs replacement.
Go to Sears's website and access parts direct section. Type in your make and model and scroll through the results. You should find diagrams, cut sheets and part numbers to ease the ordering.
Sep 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Due to power outage can't get door open on Whirlpool Duet front loader washer. With wet towels inside, need to manually open door to get them out. Is there an easy solution?
On that type of washer the door lock is wired in series with the water level switch and if water remains in tub the door lock will not power up and unlock..what you can try is (if havent already done so) is select the drain/spin only cycle and when the water has drained the door should unlock
Aug 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet has a odour, Ihave tryed leaving
all front loader washers do that ... that is why i do not recommend them there really has not been a cure for it yet, the manufactures are trying to figure out how to solve that problem
Jun 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain Hose: What Kind do I Need?
Go to Sears Parts Direct on the internet, and order from there. Or find a different hardware store (Lowe's, Home Depot, Meijer). Anywhere that sells washing machines.
Depending on where you live, there may also be a Sears Parts depot that you can go to. You can find them on the Sears Parts Direct website.
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Handle broke on whirlpool front load duet machine
there are torque screws around the door take them off and the door frame peals apart
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front loading washer - handle broke off
Replacement handles can be found at amazon... click here and take a look Modern Shower Doors at Amazing Prices. I hope this was helpful. Cheers
Dec 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Model No. GHW9100LW, Serial No. CSM2608446, Type No. 199-AWM075/GY
not unless you make it yourself ..replacement handle is just like the 1 that broke
Aug 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool replacement door handle and spring
Since this has received no response, I am closing it off my list. If you need any other help drop me a note back.
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal De
