Question about Lexmark X1270 All-In-One InkJet Printer
Buttons on printer
I no the button to switch printer on, then i have 2 white buttons and a green button also a black button theres not a booklet to explain as i have never used on bofore i am a learner where the pc and printer is concerned
  • malonee Dec 14, 2007
    i can not copy. copy face down on screen, push blacl button. noise of coping but .
  • 62 Answers
You can find the user's manual on the Lexmark website at
http://www.lexmark.com/publications/eng/1200/index.html.
Or look in your Windows Start menu if you've installed the printer.
The green button does color copy
Black button does Black & white copy
Left white button feeds paper.
Right white button sends scan to the PC. (useless)
Enjoy!
Posted on Oct 12, 2007
SOURCE:
How to print 11X17 Booklet on CS Kyocera CS3011ikx
Kyocera printers are well-known for their efficiency to produce brilliant color prints. The printer can deliver high-resolution output with crisp black and white text and graphics. The CS Kyocera CS3011ikx printer can print multiple copies that can be folded into a single booklet. Printing a booklet can minimize cost. Read through the instructions given below to understand how to print a 11X17 booklet on CS Kyocera CS3011ikx printer.
1 Press the Copy menu on the control panel to initiate the process. Select the Layout Edit tab.
2 Click the Booklet option.
3 The printer supports single-sided and double-sided printing. Choose either of them according to the printing requirement.
4 Change Default settings and mention the size of the media.
5 Place the original document or text in the document feeder.
6 Press the Start button.
7 Select the appropriate print size. Modify the size as 11X17 to meet the booklet requirement.
8 Change the page size.
9 Open the PDF document.
10 Select the options File> Print. Choose your printer from the list displayed on the screen.
11 Cut and staple the edges of your booklet. Trim the ends of the pages if it is necessary. Call our Toll-Free 1-866-293-9220
Sep 26, 2018 | Kyocera Office Equipment & Supplies
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Computers & Internet
GE Timer #15086 has red, white, green, black wires. Wall has white, black & black wires and switch sits between 3 other light switches. (I am replacing the current timer which only has 3 wires and...
GE 15086 programmable timer replaces single-pole switch only.
Single pole means 1 device turns Load on-off.
3-way is where 2 devices turn Load on-off, for example 2 switches located in hallway.
Your existing timer has white, black and blue wires.
Your new timer has white, black, red and green wires.
Green wire connects to bare ground wire in every occasion with every wiring device.
Electricians don't guess, they test the other wires.
Remove old timer.
Separate wires for testing.
Turn on power.
Tape ordinary tester leads to wood sticks to keep hands away from power.
Test each wire to bare ground wire.
Tester will light up on Hot wire. The Hot wire will connect to timer black wire.
Now test Hot wire to each other wire (except bare ground)
Tester will light up on Neutral wire. Neutral wire connects to timer white wire.
The remaining wire connects to timer red wire.
After connecting timer, push manual override button to check that Load turns on-off.
Manual override on 15086 is the door that covers buttons > use door as push button to check Load.
Next, program the timer.
Programming is straightforward and similar to other timers.
If you have a problem, add a comment.
You can also take advantage of Fixya phone support. Expert will walk you through the steps for a price.
Dec 22, 2010 | Hardware & Accessories
Photo 1290 Changing ink cartridge
You may have to reset your printer, for when the green an red are flashing. Please do the following in order to reset the printer;
1-switch off printer itself
2-switch off at socket for 20 seconds
3-hold down both black buttons on front
switch on at mains
4-switch on printer itself
green and red flash together
5-now switch off at mains and leave for 3 seconds
6-while holding down both front buttons again, switch on at mains
both green and red flash together so release
7-quickly hold down the left botton, the one with the scroll icon above it.
Hold this until it resets itself, - the print head will re
charge and it will be obvious.
Restting by unpluggin rather than turning off at mains tends not to work.
This must help you as it worked for me.
Regards,
Anirban Mazumdar
Jun 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
I have a MP160 I have not long install 2 refilled cartridges, one colour and one black and white. the computer says it does not recognise them and the alarm button and the colour and black lights are...
Hi there you can try not sure if it works.
First you must Turn off the printer
  1. Hold the Resume Button (red circle in the triangle), add a printer (click "Power") an indicator light green.
  2. Hold the Power Button, release the Resume Button.
  3. Not releasing the Power Button, double click "Resume" and release Both Buttons.
  4. Click "Resume" for Four times
  5. Once you click "Power", to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
Feb 17, 2010 | Office Equipment & Supplies
Lexmark x1240 All-In-One Printer Control Panel
Hi
This is the description of printer control panel
green button-START COLoUR COPY BUTTON.....place a documnet on scanner glass...press this button..u would get colur copies of the document
Black button-START BLACK COPY BUTTON.....place a documnet on scanner glass...press this button..u would get black copies of the document
white button on the left hand side-paper feed button..to load paper into the paper feed tray
white button the right...not sure:)....i guess it should be the scan button....
all the best
Apr 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
TROUBLESHOOTING
hi
Switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
work? reply.
Jan 17, 2008 | Toshiba 1370 Black and White Copier
C7 ERROR CODE
Your printer needs to be reseted.
Here's how to do it:
Hope it will work and solve your problem.
Black and white picture instead of color
ok.maybe the system was reset and it switch to pal mode/ntsc mode.explore ur remote control look 4 some system related button or p/n button.press it 2-3 times..u have to detailed ur unit next time..
Feb 25, 2007 | Audiovox D1420 Portable DVD Player
Lexmark X1270 All-In-One InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
