Question about ViewSonic VG2230WM LCD Monitor
Blackened out My ViewSonic VG2230wm just "went black" this morning. After several hours, I have isolated the problem to the monitor. The screen is VERY dim, but still seems to be "working," and my system can't "see" anything wrong with it. It's not that old. Is it a repair issue, or have you heard of this? Thanks.
  • 11,361 Answers
Removing back panel of a viewsonic monitor
There are almost always plastic clips along with the screws. I'd recommend buying a plastic pry bar. You can google for them online and they cost $1 or so.
Jan 30, 2013 | ViewSonic VG2230WM LCD Monitor
Viewsonic vg2230wm - the screen is blank when the computer first boots. I have to turn the monitor power switch on/off several times before the screen turns on, then it is fine.
Check your VGA (Visual Graphic Adapter) connector from your C.P.U (Central Processing Unit) to your monitor if it is intact. If it is intact , replace the VGA cable first. Then if the problem still persist check for the VGA driver in the device manager if it is correctly installed. If the problem persist try and send mail to me on greatengineerid@hotmail.com
Cheers.
Engr. Adewumi I.O
Sep 05, 2011 | ViewSonic VG2230WM 22 inch LCD Monitor
VG2230WM (Black, Gray) LCD Monitor: Will not power up, no LED power light...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | ViewSonic VG2230WM LCD Monitor
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Vg2230wm monitor Will not power on
probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
Aug 05, 2009 | ViewSonic VG2230WM LCD Monitor
Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
May 21, 2009 | ViewSonic VG2230WM LCD Monitor
ViewSonic VG2230WM LCD Monitor Logo
626 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
