Question about Sport & Outdoor - Others
2001 Yamaha Blaster is smoking. Correct oils
2001 Yamaha Blaster is smoking. Correct oils (unless snowmobile oil makes a difference) in the correct spots. correct amounts, no reason to be leaking from overflow (and it isn't) but is still smoking from exhaust.
Only does it when idling or moving in first or second, higher gears seem to get rid of it.
  • 110 Answers
SOURCE: vectra c 2.2 sri oil problem
Per previous post. A quart in 750 miles would be extremely high.  A Porsche 930 Turbo Carrera driven hard doesn't use this much unless it's motor is toast, and it is practically a race car.  You should expect at most a quart of oil consumption for 3000 miles.  A quart of oil in 750 miles is a quart EVERY OTHER tank of fuel, and would indicate a motor that needed a rebuild long ago (or seals, guides or rings).  BTW, If you can see smoke in the read view, it looks much worse when someone is driing behind you.  STP or changing to the next higher weight of oil are short term solutions that may help you not leave a trail of smoke.
If you need valve seals, maybe that's it,  but if you need guides, the rings are probably near shot too, unless there are extenuating circumstances.
cheers,
Posted on Nov 11, 2008
  • 41 Answers
SOURCE: kawasaki bayou 4x4 using engine oil alot of smoke from exhaust
if it is using oil, then u got stuck rings, which keep running the bike and keep a eye on the oil, or you need the top end rebuilt.
Posted on Nov 25, 2008
tellme2
  • 137 Answers
SOURCE: very heavy smoke from exhaust of Yamaha Virago
give the air filter a blow out m8,, and change the plugs to a hotter grade,, ie if u have ngk b8es or summat try b9,,that type of thing,
Posted on Apr 10, 2009
  • 125 Answers
SOURCE: excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
Posted on May 25, 2009
SOURCE: my blaster 200 is blowing alot of white smoke
I agree, Too much oil in the mix. I run at 40:1 at the moment but have also used 50:1 in the past with no problems.
Drain the fuel tank and re-fill with fresh 40:1 mix.
Tip the bike over on its side to run out the carb.
Good Luck.
Posted on Jul 03, 2009
Yamaha blaster 2001 starts up runs smokes bad it will hardly pull it self the throttle works good but it seems like it dont
Hi Nathan and the usual suspects are:
1. Oil tank/pan overfilled.
2. Restricted oil return line to oil tank/pan.
3. Restricted breather operation.
4. Restricted oil filter.
5. Piston rings badly worn or broken.
6. Valve guides are worn and or seals are worn, crushed, missing, or have come of guide and are literally pumping oil through the valve guide.
7. O-ring damaged or missing from oil pump at crankcase junction (also results in poor engine performance). For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/1983+yamaha+riva
Nov 15, 2015 | Yamaha Motorcycles
My xv 1100 smokes and fouls plug when it has right amount of oil in
If the oil level is correct, about the only thing remaining is worn rings. You can try another brand of oil and use a heavier oil, but it will always come back to the rings having to be changed in the end.
Mar 11, 2011 | Yamaha XVS 1100 Dragstar Classic...
How do i know if the oil levels are correct, and if it need toping up?
unless it is leaking ? you should not need to top off . If you are not
sure of your mileage you should have it changed , with filter change
as well . when doing this have the tech so you where the inspection level is at to check your oil......
Oct 21, 2010 | 2001 Yamaha SR 125
I have a 1997 yamaha 500 vmax snowmobile that the oil pump is not working. And Idon't want to replace it, I just want to mix oil and gas. But I don't know the iol to gas mix . I have contacted several...
The standard gas/oil mix is 32 to 1. That means 4 ounces of two stroke engine oil per gallon of gas. NEVER use motor oil. Only use two stroke engine oil. Please rate my answer. Thanks.
Aug 12, 2010 | Yamaha V-Max Motorcycles
Engine smokes shuts off blowing oil out exhaust
Do a compression test, you may have worn piston rings.
Apr 13, 2010 | 2003 Yamaha WR 250 F
1995 Pantera can't free rev,acts like it's starving for fuel
Hi guy, you told me alot just now. Clean your injectors well, snowmobile 2 cycles all smoke rather heavy for a few minutes after sarting so that is comon.Caused by the oil settling in the chamber after shuting off. If not for this the cylinders would freeze up being dry. You may have some bad oil in injector also if it sat for a time without being started. Just remember, never, ever use starting fuild to start WD40 works well though. Check your plugs for correct heat range and gap, again, 2 cycles are very touchy with this also. Make sure you have proper injection pressure as well as fuel injector pressure. Fresh synthic 2cycle injection oil and go cleaning should solve your problem unless there is major problems with frozzen rings.
Feb 26, 2010 | Sport & Outdoor - Others
Does the yamaha fz 750 use transmission fluid or just the motro oil
The FZ750 uses the same oil for the transmission and crankshaft and top end. All oil is stored in the oil pan below the transmission and distributed throughout the engine by an oil pump.
If you are asking if you need to use different oil for the transmission than the engine, no.
If the oil level is correct for the transmission, it is correct for the whole engine.
Oct 04, 2009 | 1992 Yamaha FZ 750 KT (Europe)
My 81 yamaha enduro is smoking badly
Same happended to me with exactly the same motorcycle... I solved the provblem by replacing the crankshaft oil seal on the rightside of the crankcase. It solved the problem immediatly!
Jun 04, 2009 | 1974 Yamaha DT 360
My 04 blaster smokes and idles poorly,dies pushing throttle
Hi I am vortash .. firstly 32 - to - 1 may be a tad high I would say ... it would be fine at the same as the ducati ratio 20-to -1 with a good quality oil , you should check that your sump is not filling with oil as this will cause performance problems with backpressure .. but maybe the best thing to do would be to replace the oil pump and run it as it was designed to do ?. I am sure you will get one off the net cheaply or from a local bike breakers .... Regards Vortash
May 18, 2009 | 2003 Yamaha YZ 250
Sport & Outdoor - Others Logo
124 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
