Question about Compaq Armada E500 Notebook
How to charge battery in compaq armada e500
Son given compaq armada battery reads zero charge how is it charged
  • 304 Answers
You need to connect the power adapter and charge it for some time and check.
Posted on May 09, 2009
Compaq armada E500 battery critical condition. How to fix it please?
Battery critical condition = the battery has aged so much that it can't be used anymore, it has become incapable of holding a charge. The only thing you can do is to replace it but finding a new one for a laptop this old is going to be tough.
Jun 18, 2010 | Compaq Armada E500 Notebook
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
Compaq Armada e500 will not turn on
hello
After reading your problem i think that your charger i malfunctioning as it is not charging the battery when it is plugged in..
The message you have mentioned comes only when your battery crosses the lower limit of charge..and your charger is not charging so it ran out..
Thank you
Aug 19, 2009 | Compaq Armada E500 Notebook
Need replace cmos battery on Compaq Armada E500
Please check the manual at this link for the proper removal procedure. In the manual, go to Removal and Replacement Procedures, and then to 5.10 Real Time Clock (RTC) Battery. It will explain how to replace the battery.
Thanks,
Lolita
Mar 05, 2009 | Compaq Armada E500 Notebook
Wondering about DVD
Hi Ladyret,I have a dvd rom fitted to my Armada 500,it is a DVD-ROM DRIVE DV-28E part No_1977067B-43 by Hewlett-Packard Company,hope this helps you.
Apr 08, 2008 | Compaq Armada E500 Notebook
Startup/charge issue
hi.. unfortunately i've seen many cases like this and it looks as if from what you are describing that your laptop is fried if there is no boot up at all.. how old is you laptop and what brand is it?
Feb 19, 2008 | HP Compaq Presario V2000 Notebook
Compaq Armada E500 Notebook Logo
265 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
