Paper feed paper roll consistently "sticks" and will not move even by using "feed" and imprints over previous numbers
  • 6 more comments
  • Kate101 Nov 28, 2007
    My paper now feeds fine after I cleaned what you said to clean. However I used a q-tip ... little rubbing alchol... Now its printing jibberish! Im not sure where my manual is. I did hit the reset ... still prints jibberish.
    The date should read 11-28-2007
    its printing : %6%9 .4 .#83%6%7M
    I must have had a "Blonde" moment...
    Any suggestions??
    Thank you in advance for any help you send my way!
    ~Kate~
  • shangie Jan 02, 2008
    I have lost the manual and cannot get a new roll of paper to feed into the machine.
  • nancy76 Jan 22, 2008
    I have lost the manual to P1-DH V and cannot get the paper roll in?Help.
    Thanks
  • Lindalouwho Feb 09, 2008
    My paper feed roller rubber has dried up and split. I've had the calculator for over ten years. Does anyone have a part # for the rubber?
    Linda
  • BBurris May 01, 2008
    I have lost my manual and cannot figure out how to reload the roll of paper correctly.
  • Anonymous May 08, 2008
    how do i install the paper roll
    I need help in adding a new roll of paper in Ibico 1214 calculator
  • mvwelsh Oct 02, 2008
    same problem
  • 21 Answers
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Posted on Feb 16, 2008
    New Friend:
@ rollers that feed paper. One on top is Black and the bottom one is White. If they are working propperly you should be able to roll one manualy with your finger and see that both are turning, if one turns and the other does not then you have a bent or distorted paper feed guide. This is proplem that happens when people try to get some JAMBED paper scrap out and bend the thin paper feed guide. The solution is to set it one fire......just kidding. You should tweek any of the openings around the 2 paper feed rollers and make shure the guide opening by the BLACK roller is bent up sufficiantly that it does not catch the paper.
Posted on Sep 27, 2011
Where is the paper path
Posted on Jun 04, 2008
Paper stuck in rollers
Posted on May 25, 2008
How do i install the paper roll
Posted on May 19, 2008
After installing new tape, the paper feed won't move
Posted on Mar 16, 2008
  • 1,113 Answers
Dirty/worn paper feed roller, gently clean rubber paper feed roller with slightly damp cloth/replace.
Posted on Oct 12, 2007
  • Soulvisitor
    Soulvisitor Oct 16, 2007
    If you press feed with no paper installed can you see feed roller turning?
    Is the paper path clear no bends or paper fragments in the path?
    Is the paper coming off the bottom of the roll into printer or off the top?
    If your calc is constantly/ never feeding/moving then it is paper feed roller, paper feed roller drive mechanism or paper path obstruction or even incorrect size paper.
    Do you have a Brand/model No.
  • Soulvisitor
    Soulvisitor Oct 21, 2007
    Help yourself then!
SOURCE:
My printer is leaving an imprint of the previous page on each new sheet on shiny label material I have been using this for a couple years for this job with this same material. This is a new problem.
There are couple possible problems here.
1. If you are reusing sheets of labels, the toner that is being printed on spots where labels are already removed will get picked up by the fuser and redeposited on the page.
2. The fuser is wearing out and toner is sticking to it and getting redeposited.
3. If you are not setting the paper type to labels, the wrong fuser temperature will be used which can cause this problem.
Keep in mind that life ratings for items like fusers are based on the following assumptions:
1. You only print on plain paper
2. Every print job consists of at least five pages.
Under these assumptions the life of a fuser in a 1215 is probably around 100K pages. Printing all single page jobs or difficult media like labels can drop that life expectancy to under 30K pages.
If you print a usage page for the printer it will show how many pages you have printed.
Sep 05, 2016 | HP Color LaserJet Pro CP1525NW Printer
Print is very light even after replacing ribbon.
My first thought is that the numbers being "hammered" against the paper are not reaching far enough. Test this theory by putting two layers of paper into the paper feed, (Fold the end of the roll over onto itself) and try printing again. It could be designed for a thicker paper.
Alternatively the new ribbon may also have dried out. Rub the ink ribbon with a paper, or pencil eraser and see if the ink readily comes off, perhaps use a pencil eraser to press it against the paper being fed through the machine.
These are diagnostics to find the error. Further investigation might be to see if there is any particles in the machine preventing it from hammering the numbers against the paper. Something might be in the way of the moving parts, something about the size of a paper hole punch paper, or pencil shaving. Shaking it vigorously upside down might solve this problem.
Good luck ;)
May 10, 2016 | Canon P170-DH Calculator
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Roller
If nothing happens no carrier movementor paper feed you probably have a bad keyboard.
If the carrier moves but no feed the index motot may need to be lubed.
If the roll moves but the paper dosen't you may have debris on the paper tray or bad lower fed rolls.
DickyO
May 03, 2013 | Lexmark Wheelwriter 1000 Typewriter
Just want to get a new roll of paper to feed in
Simply press down on the spring loaded button above the F1 key on the right side of the unit, next to where the paper feeds out of its slot - you may see the symbol of a roll of paper and a right arrow. Then after you open the new roll of paper, just place it into the cavity with the end of the roll coming out from underneath the roll itself, towards the serrated cutting blade, leaving a small amount of paper (2-3") sticking out of the top of unit. Now close the lid until you hear it click closed, and the button you pressed to begin with has returned to its 'up' position. Your paper is loaded and you may resume normal operations.
Feb 22, 2011 | VeriFone VX510
I can't get my printer to print. The error
It says paper jam because the paper bar (located just before the paper exit) can't (or does it very badly) roll. It can be caused by a lot of things that have fallen inside the printer. Open it and try to see what's blocking the bar
Oct 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper is not taken inside my printer
Its the paper feed mechnism problem. Try to clean the paper roll with cotton using warm water. if still the problem continue u need to replace the paper feed assembly.
Aug 18, 2009 | HP DeskJet 3550 InkJet Printer
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
1,648 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
