Question about Dell Inspiron 1300 Notebook
My Dell Inspiron 1300 wont start
My Dell Inspiron 1300 will start up then goes to a black screen I can't even go to safe mode or the F2 or F12 screen. Have taken the battery out and it is still doing the same thing. Any ideas?
  • Dell Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 10, 2009
Cannot get into safe mode dell inspiron 5720
Try booting from your OS (operating system software) CD,i.e. Windows XP, Vista or 7. If that works then you will need to to reload OS.
Mar 15, 2013 | Dell Inspiron 1501 Notebook
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
My Inspiron one 2305 is not working. I turn the power on and the light is solid white but after a few seconds it turns solid amber, and all i can see on the screen is the dell logo. and on the lower right...
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Mar 16, 2011 | Dell Inspiron One 2305 Desktop Computer...
My Dell 1300 Inspiron Notebook will not start up, it gets to two green lights but won't go to Four. I cannot get it to start in Safe mode, it will not recognize the command. It does recognize F2 and F12....
Hi petergreenus,
Have you tried draining the power of your system? Please follow the steps below on how to power drain your computer.
1. Turn off the computer.
2. Unplug the power cable from the outlet and remove the battery.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Press the power button and try to observe the system.
Hope it helps.
Thank you for using FixYa.
Dec 04, 2010 | Dell Inspiron 1300 Notebook
My dell inspiron cannot boot. On startup dell logo screen appears with only f2 and f12 options then my screen goes black with a flashing dash in top left corner. I cant access safe mode, i cant do anything...
The Operating System in your hard disk gone corrupt, you need new installation of Operating System using boot from CD/DVD.
P.S. Formating of Harddisk is recommended, because it seems the act of virus infection
Good Luck
DO rate if helps
Dec 02, 2010 | Dell Inspiron 1501 Notebook
I have a dell inspiron lap top with window's vista. There is a problem with it. Even when I turn it on with safe mode it goes to the log in screen, then says welcome, and then it goes to a black screen...
Usually what happens with my Dell Inspiron desktop, even on safe mode it goes to the logon screen. I have never experienced that with my Dell Inspiron 1318. When you log in and it shows you the black screen, try pressing the function buttons. Try F8 or F12. You should be able to start the computer in Safe Mode. If possible, enter Safe Mode with Networking so that you are able to search the web. If you don't mind me asking, why is it that you need safe mode? Is it a virus?
Aug 08, 2010 | Dell Inspiron 1318 Notebook
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Feb 19, 2010 | Dell Inspiron Mini 10 Notebook
I HAVE A DELL INSPIRON 1200 NOTEBOOK AND WHEN I WENT TO RESTART IT. IT WON'T START UP AFTER THE DELL PAGE IT BRINGS UP A BLACK SCREEN WITH A BLINKING WHITE LINE. I HIT F12 FOR BOOT MENU, IT DIDN'T WORK I...
ok well if that is all it dose then you are going to have to restore the computer back to factory settings and then try it but befor you do that have you tryed starting up in safe mode that might work.
please rate my help to you.
thank you.
Apr 21, 2009 | Dell Inspiron 1200 Notebook
Trouble booting past the BIOS Screen
Remove the cmos battery and unplug comptuer for about 15 to 20 minutes. install battery working battery. make sure you didn't knock any cables loose
Check ram is seated
Check video and audio cards are seated properly
Then try booting pc.
Jan 22, 2009 | Dell Inspiron 6000 Notebook
Screen goes blank soon after switching on
Try "Safe Mode" (holding F8 key on boot and selecting "Save Mode"), then run diagnostics and an up to date (virus definitions) Anti-Virus full scan.
If Safe Mode is not accessible then you may want to consider a format and clean install by booting to your Windows (?) CD.
Sep 06, 2008 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 Notebook Logo
499 people viewed this question
Alun Cox
