Question about Garden
Torque foe head bolt on Craftsman High Pressure Washer 7.0 Horsepower 2900 PSI 2.3 GPM Model Number 580.752410
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
  • 760 Answers
SOURCE: what typ of gas do i use
Regular gas 87-89 octane works fine.
Posted on Jul 14, 2010
  • 1388 Answers
SOURCE: I have a Craftsman (B & S) pressure washer 7
I worked at a tool rental store while attending college and discovered how to extend the life of tools. Really a simple trick that you practice every day. Although your car can travel at a very high rate of speed, you only use about 30 to 40 percent of its power, if however you traveled at 100 mph everywhere that you needed to go, you would greatly shorten its life. Althouth I do believe that you have received good service from your unit, you may have increased the life by using only 60 to 80 percent of its pressure potential for most general work and increase only for stubborn debris.
Posted on Apr 26, 2011
Testimonial: "Many thanks for the suggestions. Dave B"
Power boss pressure washer stops when trigger is released
The unloader on yoru pump is bad.. Pressure washer parts catalog quick links Pressure Washers High Pressure... go here with your model number on your pump and they can guide you to your new unloader. Good luck
Apr 17, 2014 | Powerboss 20309 3,000 PSI 2.5 GPM Gas...
Cant find choke on craftsman 2700 2.3 ready start 7.75
If I remember correctly, there is not an operator actuated choke on that unit. It is thermostatically controlled be a device behind the muffler.
Aug 25, 2013 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I have a Craftsman (B & S) pressure washer 7 HP 2900 psi 2.3 GPM Model No. 580.752410. It's about 4 yrs old and 2 years ago I put a seal kit 193807GS into it after it failed to put out proper pressure....
Apr 26, 2011 | Briggs & Stratton Garden
Troy bilt pressure washer will not build or reach high pressure
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Where X = a number.
Aug 31, 2009 | Briggs & Stratton Garden
No pressure to handle
sounds as if pressure relief valve is stuck open. you will have to disassemble relief valve and clean or replace.
Jun 22, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
