Question about Lakewood HV 18-c Floor / Box Fan
No power getting to my Lakewood fan...
Hi, I tripped over the power cord to my Lakewood in the dark, as it was running. I pulled the plug out of the outlet, but when I put it back there was no power going to the fan, and it seems completely dead. Is there an internal fuse or thermal trip that might need replaced / reset?
Thanks in advance
Keith
PS - I got laid off a few months ago, so would rather repair than replace
  • keithtemple May 10, 2009
    Thanks for the quick response - sadly I did the check the connections thing and all is well...
    Thanks though
    Keith
  • 38 Answers
Maybe you tripped over it so hard you de soldered the wires form the inside. Have you openned it? Try it out if you didn't. Check the power cord and follow it all the way into the motor (with the motor openned). Check if one or both cables on the inside are desoldered.
Posted on May 09, 2009
Need electric wire to plug into fan and then connect to electric outlet Where can I get one?
  • Lakewood is long out of business and a stock cord is going to be next to impossible to find. But I can help you save some money and some headaches trying to find a new cord.
  • If I remember right the 007 utilizes a simple two prong cord. The tip of the cord is simple the fatter end is your ground and the smaller end is the AC power feed. These fans don't draw to terribly much power either.
  • It is a rare occasion I would buy an original cord because they are so darn over priced. Here is what I would do.
  1. Go to your local hardware store and get a cord with a two pron tip on it. This may cost $6 top. Just a medium use cord will work for this fan.
  2. Now you will see the wires for the cord on the back of the fan motor. The hot wire is usually black (In the USA and Canada) The green wire is ground and the white wire is neural. (This is for a three wire setup. For two wire omit the white wire. The wires on your fan should be colored Black and Green. Just remember that black is the hot wire and the other is the ground.
  3. To make this less difficult the black wire off the fan will go to the wire that leads to the small end of the connector and the other wire (ground) will go to the wire (on the new cord) that tracks to the thick en of the connector. Placing your new cored flat and even makes this easier.
  4. You will need to soldier the ends (or crimp the wires together) and make sure you insulate them with liquid electric tape, shrink tube etc.
  5. Total cost should be less than $7.
  6. I did find one place that sells the 3 prong cord http://www.nelsonappliance.com/Power+Cords+for+Lakewood+model+MC42+Fan.html for the fans. If yours should be a 3 prong tip then this one will work too but if memory serves yours is a two tip cord.
  • If you have any questions or comments please feel free to ask but you won't find a stock cord just for this fan because they are out of business.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 18, 2011 | Lakewood 007 Floor / Box Fan
I have this Lakewood fan and we have misplaced the cord to it. Is there any way to get a replacement cord?
heres their toll free number 1-888-777-0772 good Luck,, Please take a moment to rate my response
May 28, 2011 | Lakewood HV9 Floor / Box Fan
Trying to find replacement electric cord for Lakewood mc 24 lg drum fan
The Lakewood fan uses a computer power supply type female plug.
This is known as a C13 plug: three rectangular female outlets in a triangular pattern.
You should be able to find this type of plug at a good electronics store;
Fry's Electronics would be a good choice.
It may not come in the 10 foot length of the original, but that is what extension cords are for. :)
Sep 21, 2010 | Lakewood (r) Industrial Drum Fan (MC-24)
I lost the cord that plugs in - where can I find a replacement cord?
Hi, this is not a special type of cord, so just go to any hardware store such as Ace, Home Depot, and they will fix you up.
Sincerely,
Shastalaker7
Sep 03, 2010 | Lakewood 200I Floor / Box Fan
Need replacement for lakewood box fan power cord
Use some needle nose pliers on the prongs and bend them back. They will be fine unless they broke off.
Aug 30, 2009 | Lakewood HV 18-c Floor / Box Fan
It seems like no power is going to the fan. it is completely dead when turned on
Fan is pretty simple, plug, cord, switch or motor. You can check the 1st 3 with an ohm meter. Just check for continuity, seeing if the different parts are good. If all are good, need new motor, or replace fan.
Jul 01, 2009 | Lakewood HV-12-c Floor / Box Fan
My window unit fell out of the window and hung by the power cord that was still plugged into the wall. I was able to grab the cord and pull it back up. I reattached the power cord and now every time i turn...
Its most likely is not the switch. It is most likely the cord though. Due to the excess strain on the cord it has probably cut through the rubber coating on the wire and connected to the frame and grounded the hot lead. Fix the cord and you may have it handled.
Jun 15, 2009 | Frigidaire FAX054P7A Wall/Window Air...
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
Current device on cord trips
Sound to me like its pulling too much amps due to back dirty coils, check this coils where the fan blades throw the water on the coils ,this could be getting clogged! or low on freon, not enough cool gas to keep the compressor from getting hot!I
Aug 26, 2008 | Frigidaire Heating & Cooling
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
May 27, 2007 | Lakewood 200I Floor / Box Fan
Lakewood HV 18-c Floor / Box Fan Logo
441 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
