SOURCE: 1995 Audi A6 won't go past seond gear
one reason for stuck in 2nd gear its anti theft if u have remvd fuses and replaced it takes it as tampering and the computer has to be reset which costs at audi agents but i got from autoelectrician that if u disconnect battery for ten minutes then re connect it re sets the onboard computer i had same problem and ive done it twice with mine with success could be same with yours try it its so inexpensive
SOURCE: 1996 Audi A4 2.8L will not shift into reverse or park
You need a new inhibitor switch on the gear selector.
SOURCE: shift lock light stays on in drive
sounds like something might have gotten into the shifter mechanism. several things could get in there like the accordian strip around the shift handle, coffee or soda could be spilled in there,....ext. another possibilty is the shifter cable going bad . I'd disconnect the shifter cable from the tranny and see if it all moves free then, if not any better take apart the shifter itself and see whats making it hang-up.
SOURCE: 1998 audi a6 quatro automatic. shifts fine 1st
you may have a faulty tcm (transmission control module)
