Question about Kitchen Appliances - Others
Fenceman CP250 - electric fence guard pulser. It has an internal Neon which has disintegrated I need to know its specification to replace it. I have tried unsuccessfully to get the manual and am quite prepared to buy it too. The neon is in series with the HT feed so it is required as far as I can make out. The neon is in series with 2 x 47K resistors from the HT pulse transformer. Thank you Peter D
  • 1 more comment
  • peter264 May 09, 2009
    Hello thank you.
    Your answer to my problem was a link to buy a NEW pulser which obviously is not what I want. Can you help further or, with respect, shall I seek another expert?
    Thanks
    Peter
  • peter264 May 10, 2009
    Unfortunately the EXPERT was not able to assist me AT ALL, he obviously had not read my original post (problem)fully. Shall we try again or perhaps forget the whole idea ?? as, with respect, I am not willing to keep having to reply to negative emails.
    Thank you.
    Peter Dobson
    Please, with respect NOBODY is understanding my question. I appreciate your time in submitting the PDF file BUT this PDF only describes what a electric fence is all about and HOW to use them. I have used electric fences of all types for over 20 years so I think I could have written that PDF file.
    My problem is ELECTRICAL !!! as I have described originally, please if you cannot answer my question lets forget the whole thing, but I will require your promise that I will not be billed for anything as you state in your advertising data.
    Thank you
    Peter Dobson
  • 5,807 Answers
The neon can be found in many ways , you can dismantle the switch with the most common switch that lights when you power it on, neon light is just an ordinary light , you can series it with 220k direct connection to 220v it should light. example also is the national switch it turns on at night( actually only visible ) so that you have a guide turning on the light. but i think that is all for the neon light. its main purpose in your circuit is primely to give or monitor pulses from the oscillator transformer a small one.it is connected in series with a resistor to provide timing for your scr to conduct thus making the light flicker. the scr can also be found anywhere it is mostly used nowadays with so many replacement that will work. hope this help
Posted on May 10, 2009
  • Rommel Cana
    Rommel Cana Jun 10, 2009
    have you found the replacement?
    Novelist:
  • 130 Answers
    Brigadier General:
  • 3,917 Answers
Please on the link provided.
http://www.horse-clippers.com/index.php?section=sitemap
Thanks
Posted on May 09, 2009
  • e-Guru
    e-Guru May 09, 2009
    My appologies.
    The catologue number for the neon would be : Cat Ref: MDC0044
    For your reference please move to page 7 of a 21 pages documnet found in the bellow mentioned link:
    www.getsmart.uk.com/brochure_download.php
    Thanks for your time and patience.
Need hand guard limbntrim part#108626-01
suggest calling the company .your instruction manual should list the number
Mar 09, 2015 | Desa International Remington 14" Electric...
Opener makes a lot of noise
The sounds can be coming from your internal gear that has started to go , open the cover and check for nylon shavings from the nylon main gear , if this is the case replace ! If that's not the problem then you can always take the metal cover off and line the metal housing with electrical tape ,this will keep the metal on metal contact from the housing and the cover from making metal vibrations that will also cause the unit from sounding lioder then it is! Hope this helps sincerely Glenn
Sep 06, 2014 | liftmaster Professional Garage Door...
Why do they say en guard at the beginning of a fencing match?
The referee says en guard, French for on guard, at the begging of a match to signify that they opponents need their guards up.
Jul 09, 2012 | Sport & Outdoor - Others
The blade is not sqare to the front of the table, with the fence next to the blade there is a 1/8 inch differance. how do i adjust the blade or the motor/shaft
you don't adjust anything but the fence if I understand the question correctly. You are using the fence for a straight cut and there is a gap, if so on the back of the saw UNPLUG SAW FIRST you will find a schematic about hhow to adjust the fence but all you have to do is loosen the 2 bolts where the arrows are I believe they are 10MM and lift the guard out of the way then gently run the fence next to the blade and "push" the fence square to the blade and tighten the bolts, usually it takes a couple times (I always recheck it). Now if the blade set at 0 degrees is not square you reset the angle from the front. Let me know if you need more help
Feb 25, 2011 | Dewalt DW744X 10" Portable Table Saw
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
Need a rip fence
Howdy, Here is the ordering page link with the rip fence (called edge guide, part number 2610997206 by Bosch) from Bosch:
https://www.boschtoolsservice.com/Search/QuickPartsOrder.aspx
I would recommend looking in a pawn shop or ebay as the rip fence is nearly 100 dollars as a replacement part.
Hope this helps a bit:)
Regards, Farmerbear
Sep 08, 2010 | Bosch 4000 - 07 Electric Table Saws
Sir, i have bajaj pulser 150, i bought in 2007.
Under the clocks are a set of wires. Make sure they are all in place. It sounds like there is a loose connection but once you're moving it fixes itself.
Make sure the earth wires from the battery are secure, a loose or rusty earth wire can cause electrical annoyances.
Hope this helps and vote if you are happy with it.
Jun 24, 2010 | 2005 Bajaj Pulsar 150
Miami airport quantum of solice
You should go back switch the door twice a gain and then go further over the fence.
Apr 07, 2009 | Video Game Consoles & Games
Kitchen Appliances - Others Logo
977 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
