Question about Brother MFC-5440CN All-In-One InkJet Printer
How do I empty the ink resevior in my brother mfc 5440cn printer
I am needing to empty the ink resevior on my printer. It is a brothers mfc 5440cn. How do I go about doing this. There is no repair shop in my area so I will need to try to do it myself. I don't want to just trash it if I can keep from it.
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
Mix-it-up
  • 832 Answers
SOURCE: OCR with Brother MFC 5440CN
you can program by help of the brother control center. open cc and set readiris as the ocr prog. (actually the paperport prog has a built-in ocr engine)
Posted on Apr 11, 2008
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Posted on Apr 24, 2008
mitpatterson
  • 74 Answers
SOURCE: Ink Absorber Box
If you lift the scanner and then carfully remove the cover that is on the same side as the ink cartridges the box should bein the back and you can remove it and clean it and let it dry for a while then reinstall it. if you need more help just do a live chat request for ME and i will help you
Posted on Jul 30, 2008
Unable to clean message. cant see why. Brother's web site is no help.
Posted on Aug 09, 2008
Brother MFC-5440CN wont feed 2 colors of ink, Yellow and Magenta and also says
This may be due to the fact that you have not removed correctly the small label that seals the air input to the cartridge. Normally on brother cartridges it's on the back or on the top of the colored label. Please check that. If no air is allowed in then your ink will not be provided thus generating your problem.
Oct 27, 2011 | Brother MultiFunction Center MFC-440CN...
Using my sons computer. Black ink has run out - no idea how to change it. Brother MFC - 5440CN. Son told me on phone to lift up right hand side of white part. Can't even find part he's talking about. ...
<a href="http://www.brother-usa.com/modeldocuments/consumer/users%20manual/um_mfc_5440cn_5840cn_en_108.pdf">http://www.brother-usa.com/modeldocuments/consumer/users%20manual/um_mfc_5440cn_5840cn_en_108.pdf</a><br /> plz check the manual for the above website
Aug 25, 2010 | Brother MFC-5440CN All-In-One InkJet...
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Not printing
i have a brother mfc 5440cn printer,error message says out of black ink,i replaced it,still says out of ink,i opened and checked micro switch,then bypassed micro switch,still reads out of black ink and wont go any further than that
Sep 29, 2008 | Brother MFC-5440CN All-In-One InkJet...
INK
Brother multifunction printers require that all ink be filled before you can print to it. If any ink is empty, you cannot print, even if you are printing only black.
Jun 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
