Question about Dell Dimension 2350 PC Desktop
Desktop cpu shuts down shortly after startup
Problem with dell dimension 2350 shuts down after startup
  • 1 more comment
  • rjblittle
    rjblittle May 11, 2010
    can you please explain more about the problem?
  • pin_0018
    pin_0018 May 11, 2010
    Give more info about the Sound or the Event Which happen after u put the system on.
  • Thomas F. Schneider May 11, 2010
    What does it say . Does it get to the beep part?
    Fans running?
  • 433 Answers
I if you haven't added any new hardware or software since this problem started check the following:
I would be thinking a heat problem. Check on the BIOS log looking for Thermal Events...check to see if the fan on your processor/sync. is tight and spinning. Check to see all fans are spinning and clean out dust. If you are satisfied that that is not the problem, look to your video card. Do a reinstall or update on the Vid drivers.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_CEL_2350&os=WW1&osl=en&catid=&impid=
It should be one of these two things...if not memory would be my next concern.
Posted on May 10, 2009
Dimension 2350, on stARTUP ONLY
Remove the power cord, remove the case and look inside the computer at the capacitors. See if any of them are busted or leaking corrosion. The capacitors look like little battery towers but they are not as tall as AA or AAA batteries.
May 02, 2012 | Dell Dimension 2350 PC Desktop
Cpu fan can't run on dell dimension
You can clean or replace the fan.
Get the manual from www.dell.com/support
You can download it free and look up the fan repair instructions.
Hope this helps.
Mar 05, 2012 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
The dell dimentions 2350
Ensure that both the case fan and CPU fan are dust free and spinning. I think it could be overheating and then shutting itself off to prevent damage
Feb 01, 2010 | Dell Dimension 2350 PC Desktop
How to remove and replace cpu for dell dimension desktop 2350
the cpu is a intel remove and replace a cpu is very easy
This link may help it is the rong model but dictates the process
You will need to open the case and be carefull of statick
ab510a2.jpg look for the cpu heatsink
Remove the fan unscrwe on the top
then remove the silver part this is held on with clips
gentley remove the cpu and replace new one THE RIGTH WAY look for the corners on the cpu to mach up on the board
Nov 24, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 cpu fan failure
i can help with the mouse & keyboard.
go into the bios on boot screen you press DEL i think then activate the USB mouse & keyboard option then save & exit.
there will be settings for the cpu fan in there somewhere but i can't remember where sorry.
Aug 16, 2009 | Dell Dimension 2350 PC Desktop
My CPU fan for my Dell Dimension 2350 has stopped turning!
If your fan is not turning at all then it is probably dead, the bearings are likely clogged with dust and such. The PC is shutting off because of heat buildup on the processor chip. You need to do an Ebay search for your model and order a fan right away. Continued running of your sysem without a fan will kill the processor and motherboard. You should be able to get a replacement fan for your computer for less than $15 including shipping. Your local computer store may have one to fit your system but they may charge more for it. To change the fan is very easy, the left side of the case will come off your system, right under the power supply is the processor and heatsink and the fan. Disconnect the old fan and reconnect the new unit.
I hope this helps, if so please rate my solution
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 02, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 shuts off after a few minutes
Definitely check the power supply fan and the CPU fan for dust. Overheating could be the culprit, good luck.
Mar 18, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 PC Desktop Logo
163 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
