Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How to lock drive shaft to change reverse disk?
A friend gave me an older model Troy Built tiller and I am trying to replace the reverse wheel. I have some experience working on machines and am looking for hints to change the reverse disk. Mainly to lock the shaft so as to loosen the retaining nut holding the disk. I am sure there is a easy way but I am not seeing it. Any help would be great, Thanks Chas.
I just changed the belts on my tiller, and had the same problem..The manual says to be on the left side of machine and with a box end wrench on the bolt, "hit with a hammer"..use a brass or lead hammer..
This sometimes works, but you still have to tighten it when you are done!
My tiller has electric start, so the easy way was to remove starter and position a piece of wood against the ring gear.
John
Posted on May 26, 2009
Troy bilt rear tine tiller will not free wheel. works forward and reverse no problem. Model 12209
are the wheels held on with hitch pins? if yes you have to remove those to roll the beast. remove pin slide wheel to the inside replace pin. i know it sounds silly which is what i thought too. it is what it is. good luck
Jul 04, 2017 | Troy Garden
Fuel line diagram for troy built tiller
Try reversing fuel lines. They may be connected to the wrong ports.
Jul 05, 2014 | Yard Machines Cultivator
Disengage wheels from transmission
Pull out the bolts that bolt the wheels to the axle,then the wheels will freewheel.
Apr 26, 2010 | Troy-Bilt Pony Garden Tiller
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What year Troy Built Horse Tiller
The serial number is stamped on the upper right hand side of the gear housing. It is on a flat spot just above the wheel shaft. If it is a newer model it will be on a white sticker on top of the gear housing plate. If it has the T handle it is probably an older 1980's model. If you find the six digit number I can give you the year it was made.
Frank
Aug 03, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have 1980's model troy built pony tiller that won't fire
Great machine, I had one. The points need replacement. Look for a gadget that replaces the points. I found mine in PepBoys. Search the Internet, the cost was about $5.00.
May 17, 2009 | Troy-Bilt Pony Garden Tiller
Free wheel
Shift your Wheel gear lever to "disengage". Use the disengage position only when the engine is not running.
Apr 19, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a older troy-built tiller (horse), belts slip under load
Remove the Belt, take it to an a Auto parts store and buy a smaller one, the replacement engine may not be exactly as the old one was
Apr 18, 2009 | Garden
Changing the drive belt
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
303 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
