Question about GE GSS25SGMBS Side by Side Refrigerator
Defrost cycle is not working
The coils in the freezer frost over and make it unable to circulate the cold air. the fridge is usually about 60 degrees and the freezer is about 40. i dont know much about refridgerators but im pretty sure it has something to do with a defrost timer, heater and/or thermostat. is there a way to find out which of these are the actual problem and also ways to manually install them? thank you to anyone who attepts to help. i really apreciate it
  • Thomas F. Schneider May 11, 2010
    The defrost time is usually an electric lock often located behind the front kickplate. Their is a hole in it covered with tape that one can take off the tape from and see if the flywheenn of the clock is going around. Sometimes one can oil the shaft for the timer to the switch and wil cure the problem.  The thermostat is not the problem as you tempatures are correct and defrost is based upon time only.Most don't have heaters,either.
    Problem Solver:
  • 19 Answers
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # off your data plate ready.
Posted on May 09, 2009
Wont cool
you didn't specify if it is the fridge or freezer that is not cooling. Whichever the case maybe, I would diagnose both the fridge and freezer.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover. 2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover. 3. Disconnect the defrost thermostat wiring connector. 4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Jul 11, 2011 | Refrigerators
I've recently been having trouble with my american fridge freezer. The freezer isn't freezing and the fridge is barely cold. The motor is working and there is some cold coming from somewhere but...
Good luck.
Jul 10, 2011 | Refrigerators
Ge arctica side by side. Freezer not freezing refrigerator not cooling
Good luck.
Apr 09, 2011 | Kitchen Ranges
It stopped cooling yesterday without any warning signs
Take care.
Apr 08, 2011 | Refrigerators
My fridge /frezer stop working
Good luck.
Apr 07, 2011 | Frigidaire Refrigerators
Fridge section of fridge/freezer not working .
Take care.
Apr 07, 2011 | Zanussi Refrigerators
Not freezing and not getting cold
Take care.
Mar 31, 2011 | Hotpoint FFA90 Bottom Freezer Refrigerator
Not cooling on either side model #106.54606300
When you say it not cooling on either side, do you mean both the freezer and fridge is not cooling? If yes, read further.
Good luck.
Mar 31, 2011 | Kenmore Side by Side Refrigerator
Not cooling properly in freezer and refrigerator
Good luck.
Mar 07, 2011 | Whirlpool Refrigerators
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
GE GSS25SGMBS Side by Side Refrigerator Logo
161 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
