Mitsubishi Projection TV - Screen is Too Small for Picture
Recently, our TV picture started looking stretched and too big for the screen.  The people look squashed and words are cut off on the sides.  I checked the format settings, and it is set to "standard", which is the default setting.  There is a "stretch" option, but it is not on.  Is there anything else we can do to get the picture to fit the screen, or does it need a new part?
Thank you!
    Master:
  • 461 Answers
I would need more information for your tv however it sound like you may end up needing to replace the main board.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Posted on Jun 10, 2017
6ya staff
SOURCE:
Anonymous
  • 192 Answers
SOURCE: Format stuck on Mitsubishi WS-55511 Rear Projection TB
Normallly, if the format button on the remote does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Posted on Mar 04, 2007
Anonymous
  • 6 Answers
SOURCE: Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Posted on Nov 26, 2007
Anonymous
  • 192 Answers
SOURCE: Picture size
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Posted on Jan 05, 2008
Michael Borelli
  • 979 Answers
SOURCE: Mitsubishi hd 1080
The format of what you are watching plays a major part in whether all of the screen is used. If the program is 4:3 the screen will remain pretty much square. 16: 9 would be the most desirable for filling all the area. Go ahead and acquire a manual, they're not much...accordianman
Posted on Feb 27, 2008
JULIANFIX
ALBERT GARCIA
  • 975 Answers
SOURCE: setting is set to 480i stretched, can I change this or...
the display format for this unit is 1080i , so yes you should be able to change the format , I guess your gonna need the remote for this setting , in case you decide to get a remote , let me give this link , good luck and hope my solution is helpful.
www.remotecontrolwarehouse.com/MITSUBISHI/290P111010.html
Posted on Apr 26, 2008
How do i change the picture to fit the tv screen
Mitsubishi usually has a button on their remotes labeled 'format' and can stretch the pic to fill the screen more, but sometimes a funky picture is the result
Mar 21, 2013 | Mitsubishi WD-65833 65" HDTV
I have a mitsubishi big screen digital projection TV the picture is starting to look oval shaped in the screen not flat what part should i be looking at to fix problem
A lot here depends on the actual model number and if you could post a good photo of it somewhere(here or elsewhere) I might be able to still assist you.
Mar 20, 2012 | Mitsubishi Televison & Video
Have sound but no picture. We have comcast and can only see a small screen in upper right corner after pushing the menu button. In this picture, I do see my comcast channels and I am able to change them...
Look inside front panel under RHS picture tube for leaked fluid. If you see a puddle on signal board, take tv to street - it is unrepairable then. The coolant is poisionous.
If that looks ok, then make sure you're using original Mits. remote.
Hope this helps.
Jan 18, 2011 | Mitsubishi VS-50703 50" Rear Projection...
Heard loud popping sound with tv off. When I turned it on the picture stretched across screen with a dip in the center. Started ~ 4 months ago. The video picture does not show centered on screen(the...
Sorry the problems u have is not for hobbiest or amature to do.High voltage Deflection board areas.This problems,must have experience tv tech to troubleshoot and replaced parts or boards require for the tv.Could be extensive repairs or just requiring test and replaced some of many small capacitors,resistors,transistors and ICS.Have to do major troubleshooting though.Must get priced quotes by many big screen tv shops,than u decide,which to give the job to.
Dec 09, 2010 | Samsung 50" Slim-Depth DLP HDTV
PICTURE IS TO BIG
You probably have the TV set to "Stretch" you can change this with a simple click of your remote control. Look for a button that says "View" or "Zoom" on it
Nov 27, 2009 | Mitsubishi Televison & Video
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Dec 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
