Question about Durabrand BH1304D 13" TV
ON CHANNEL 47 THERE IS A BLACK SCREEN WITH DATE, TIME AND LID://T
THE ONLY WAY IT GOES AWAY IS TO PRESS "DISPLAY" BUT IT COMES RIGHT BACK ????
    President:
  • 2,992 Answers
Check the closed-caption settings on the TV. It's probably set for "text" now and should be "off". In text mode the screen is blanked out to make room for the text display, but there isn't any. On many channels or programs you'll never see anything, but it sounds like your channel 47 is actually presenting something.
Posted on May 09, 2009
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Black box in middle of screen/picture
Closed Caption function to that channel you select is ON. Make it OFF, when you are in that channel which displays this black box. It will be best to reset the TV to its factory settings first, and then re-tune it. for more details, refer its user manual.
Jul 10, 2012 | RCA L32WD26D HDTV/DVD Combo
The screen goes black. On every channel. Sound is perfect. Is the TV dead
Ok---let me describe something and you tell me if your case: Set comes on and has audio--after 2-5 minutes if you look closely at the screen do you see a odd and faint band of noise top to bottom and to the right of the center of the screen?
It takes a couple minutes and will be faint and easy to miss.
Let me know what you see.
Apr 24, 2012 | Panasonic PT-47WX49 47" Rear Projection...
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
Lost the time and date line in the display
Unplug the phone, wait one minute, then plug it back in and see if the display comes back on. Press the program button, press 22 on the dial pad, press program button again ( if the phone is ringing on the incoming call and not just flashing).
May 31, 2008 | Panasonic KX-T7630 Corded Phone
Durabrand BH1304D 13" TV Logo
105 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
